ArcGIS.Desktop.Mapping Namespace / MapView Class / AddOverlayControl Method
A class containing the control to add. MapViewOverlayControl can be used or create another class that implements IMapViewOverlayControl.
Example
    Add a control over the view.
    Syntax
    Public Sub AddOverlayControl( _
       ByVal overlayControl As IMapViewOverlayControl _
    public void AddOverlayControl(
       IMapViewOverlayControl overlayControl
    Parameters
    overlayControl
    Remarks
    The control should be held in a member variable if access is required later, or to send to RemoveOverlayControl when no longer needed.
    Example
    MapView Overlay Control
      //Create a Progress Bar user control
      System.Windows.Controls.ProgressBar progressBarControl = new()
        //Configure the progress bar
        Minimum = 0,
        Maximum = 100,
        IsIndeterminate = true,
        Width = 300,
        Value = 10,
        Height = 25,
        Visibility = System.Windows.Visibility.Visible
      //Create a MapViewOverlayControl.
      var mapViewOverlayControl = new MapViewOverlayControl(progressBarControl, true, true, true, OverlayControlRelativePosition.BottomCenter, .5, .8);
      //Add to the active map
      MapView.Active.AddOverlayControl(mapViewOverlayControl);
      // Note: Needs QueuedTask to run
        //Wait 3 seconds to remove the progress bar from the map.
        Thread.Sleep(3000);
      //Remove from active map
      MapView.Active.RemoveOverlayControl(mapViewOverlayControl);
    Requirements
