ArcGIS.Desktop.Mapping Namespace / MapView Class / ZoomOutFixed Method
The amount of time to navigate the view to the new camera position. If null it uses the default navigation duration.
Example
    ZoomOutFixed Method (MapView)
    Zoom the Camera out by a fixed amount. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function ZoomOutFixed( _
       Optional ByVal duration As Nullable(Of TimeSpan) _
    ) As Boolean
    public bool ZoomOutFixed(
       Nullable<TimeSpan> duration
    Parameters
    duration
    Return Value
    True if the navigation is completed, false if it was interrupted by another view navigation.
    Exceptions
    ExceptionDescription
    Example
    Fixed Zoom Out
      // Note: Needs QueuedTask to run
        //Zoom out in the map view by a fixed amount.
        mapView.ZoomOutFixed();
    Requirements
