ArcGIS.Desktop.Mapping Namespace / MapView Class / SelectVoxelLockedSection Method
Example
    Selects the voxel locked section in the TOC.
    Syntax
    Public Sub SelectVoxelLockedSection( _
       ByVal section As LockedSectionDefinition _
    public void SelectVoxelLockedSection(
       LockedSectionDefinition section
    Parameters
    section
    Example
    Get/Set Selected Voxel Assets from the TOC
      var surfaces = MapView.Active.GetSelectedIsosurfaces();
      //set selected w/ MapView.Active.SelectVoxelIsosurface(isoSurface)
      var slices = MapView.Active.GetSelectedSlices();
      //set selected w/ MapView.Active.SelectVoxelSlice(slice)
      var sections = MapView.Active.GetSelectedSections();
      //set selected w/ MapView.Active.SelectVoxelSection(section)
      var locked_sections = MapView.Active.GetSelectedLockedSections();
      //set selected w/ MapView.Active.SelectVoxelLockedSection(locked_section)
    Requirements
