Public Function GetSelectedSlices() As IReadOnlyList(Of SliceDefinition)
public IReadOnlyList<SliceDefinition> GetSelectedSlices()
Return Value
The collection of voxel slices selected in the TOC.
var surfaces = MapView.Active.GetSelectedIsosurfaces();
//set selected w/ MapView.Active.SelectVoxelIsosurface(isoSurface)
var slices = MapView.Active.GetSelectedSlices();
//set selected w/ MapView.Active.SelectVoxelSlice(slice)
var sections = MapView.Active.GetSelectedSections();
//set selected w/ MapView.Active.SelectVoxelSection(section)
var locked_sections = MapView.Active.GetSelectedLockedSections();
//set selected w/ MapView.Active.SelectVoxelLockedSection(locked_section)
// Note: call within QueuedTask.Run()
var slice = MapView.Active?.GetSelectedSlices()?.FirstOrDefault();
if (slice != null)
//Do something with the slice
voxelLayer = null;
if (slice != null)
voxelLayer = slice.Layer;
//TODO - use the layer
