ArcGIS.Desktop.Mapping Namespace / MapView Class / NextCameraAsync Method
The amount of time to navigate the view to the new camera position. If null it uses the default navigation duration.
Example
    Go to the next camera position.
    Syntax
    Public Function NextCameraAsync( _
       Optional ByVal duration As Nullable(Of TimeSpan) _
    ) As Task(Of Boolean)
    public Task<bool> NextCameraAsync(
       Nullable<TimeSpan> duration
    Parameters
    duration
    Return Value
    True if the navigation is completed, false if it was interrupted by another view navigation.
    Remarks
    This method can be called multiple times in a loop to go through multiple camera positions. Use together with the HasNextCamera to test if there is a next camera available.
    Example
    Go To Next Camera
      //Zoom to the selected layers in the TOC
      if (mapView.HasNextCamera())
        mapView.NextCameraAsync();
    Requirements
