ArcGIS.Desktop.Mapping Namespace / MapView Class / GetSelectedLockedSections Method
Example
    Returns the collection of voxel locked sections selected in the TOC.
    Syntax
    Public Function GetSelectedLockedSections() As IReadOnlyList(Of LockedSectionDefinition)
    public IReadOnlyList<LockedSectionDefinition> GetSelectedLockedSections()
    Return Value
    The collection of voxel locked sections selected in the TOC.
    Example
    Get/Set Selected Voxel Assets from the TOC
      var surfaces = MapView.Active.GetSelectedIsosurfaces();
      //set selected w/ MapView.Active.SelectVoxelIsosurface(isoSurface)
      var slices = MapView.Active.GetSelectedSlices();
      //set selected w/ MapView.Active.SelectVoxelSlice(slice)
      var sections = MapView.Active.GetSelectedSections();
      //set selected w/ MapView.Active.SelectVoxelSection(section)
      var locked_sections = MapView.Active.GetSelectedLockedSections();
      //set selected w/ MapView.Active.SelectVoxelLockedSection(locked_section)
    Get Selected Locked Section in TOC
      var locked_section = MapView.Active?.GetSelectedLockedSections()?.FirstOrDefault();
      if (locked_section != null)
        // Use the locked section
    Get Voxel Layer for the Selected Locked Section in TOC
        voxelLayer = locked_section.Layer;
        //TODO - use the layer
    Set the Variable Profile Active for Selected Locked Section
      // Note: call within QueuedTask.Run()
          var variable = locked_section.Layer.GetVariableProfile(locked_section.VariableName);
          locked_section.Layer.SetSelectedVariableProfile(variable);
    Requirements
