ArcGIS.Desktop.Mapping Namespace / MapView Class / RemoveExploratoryAnalysisAsync Method
A subclass of ExploratoryAnalysisBase to remove from this view.
    Removes the provided ExploratoryAnalysisBase instance from the MapView. It will no longer be tracked or drawn in the view. The parameter provided should be destroyed after it has been removed to avoid errors or confusion.
    Syntax
    Public Function RemoveExploratoryAnalysisAsync( _
       ByVal item As ExploratoryAnalysis _
    ) As Task
    public Task RemoveExploratoryAnalysisAsync(
       ExploratoryAnalysis item
    Parameters
    item
    Return Value
    A task that can be queried to know when the Exploratory Analysis object has been removed from the MapView.
    Requirements
