ArcGIS.Desktop.Mapping Namespace / MapView Class / Map Property
Example
    Map Property (MapView)
    Gets the map or scene associated with the view.
    Syntax
    public Map Map {get;}
    Public ReadOnly Property Map As Map
    Example
    Lookup Symbol
      //feature layer from the active map
      var lookupMapView = MapView.Active;
      var featureLayerLookUp = lookupMapView.Map.GetLayersAsFlattenedList()
                              .OfType<FeatureLayer>()
                              .FirstOrDefault();
      await QueuedTask.Run(() =>
        //Get the selection
        var selection = featureLayerLookUp.GetSelection();
        //Get the first Object ID
        var firstOID = selection.GetObjectIDs().FirstOrDefault();
        //Determine whether the layer's renderer type supports symbol lookup.
        if (featureLayerLookUp.CanLookupSymbol())
          //Looks up the symbol for the corresponding feature identified by the object id.
          var lookupSymbol = featureLayerLookUp.LookupSymbol(firstOID, lookupMapView);
          var jSon = lookupSymbol.ToJson(); //Create a JSON encoding of the symbol
                                            //Do something with symbol
    Get the active map
      //This is how you get the active map
      var mapToGet = MapView.Active?.Map;
    Get Map Panes
      ProApp.Panes.OfType<IMapPane>().OrderBy((mp) => mp.MapView.Map.URI ?? mp.MapView.Map.Name);
    Get the Unique List of Maps From the Map Panes
      //Gets the unique list of Maps from all the MapPanes.
      //Note: The list of maps retrieved from the MapPanes
      //maybe less than the total number of Maps in the project.
      //It depends on what maps the user has actually opened.
      var mapPanes = ProApp.Panes.OfType<IMapPane>()
                  .GroupBy((mp) => mp.MapView.Map.URI).Select(grp => grp.FirstOrDefault());
      List<Map> uniqueMaps = new List<Map>();
      foreach (var pane in mapPanes)
        uniqueMaps.Add(pane.MapView.Map);
    Change the Map name and caption of the active pane
      var activeMap = MapView.Active?.Map;
      await QueuedTask.Run(() => activeMap?.SetName("Test"));
      ProApp.Panes.ActivePane.Caption = "Caption";
    Clip Map to the provided clip polygon
      var mapToClip = MapView.Active.Map;
        //A layer to use for the clip extent
        var lyrOfInterest = mapToClip.GetLayersAsFlattenedList().OfType<FeatureLayer>().Where(l => l.Name == "TestPoly").FirstOrDefault();
        //Get the polygon to use to clip the map
        var extent = lyrOfInterest.QueryExtent();
        var polygonForClipping = PolygonBuilderEx.CreatePolygon(extent);
        //Clip the map using the layer's extent
        mapToClip.SetClipGeometry(polygonForClipping,
              SymbolFactory.Instance.ConstructLineSymbol(
              SymbolFactory.Instance.ConstructStroke(
                ColorFactory.Instance.BlueRGB, 2.0, SimpleLineStyle.Dash)));
    Clear the current map clip geometry
      var mapWithClip = MapView.Active.Map;
      //Clear the Map clip.
      //If no clipping is set then this is a no-op.
      mapWithClip.ClearClipGeometry();
    Get the map clipping geometry
        //If clipping is set to ArcGIS.Core.CIM.ClippingMode.None or ArcGIS.Core.CIM.ClippingMode.MapSeries null is returned
        //If clipping is set to ArcGIS.Core.CIM.ClippingMode.MapExtent the ArcGIS.Core.CIM.CIMMap.CustomFullExtent is returned.
        //Otherwise, if clipping is set to ArcGIS.Core.CIM.ClippingMode.CustomShape the custom clip polygon is returned.
        var poly = mapWithClip.GetClipGeometry();
        //You can use the polygon returned
        //For example: We make a polygon graphic element and add it to a Graphics Layer.
        var gl = mapWithClip.GetLayersAsFlattenedList().OfType<GraphicsLayer>().FirstOrDefault();
        if (gl == null)
          return;
        var polygonSymbol = SymbolFactory.Instance.ConstructPolygonSymbol(CIMColor.CreateRGBColor(255, 255, 0));
        var cimGraphicElement = new CIMPolygonGraphic
          Polygon = poly,
          Symbol = polygonSymbol.MakeSymbolReference()
        gl.AddElement(cimGraphicElement);
    Get the Grid Options for a Map
      var gridOptionsMapView = MapView.Active;
      if (gridOptionsMapView == null)
        return;
        //Does the 'map' currently have any options?
        var hasOptions = GridOptionsEnvironment.Instance.HasGridOptions(map);
        //If grid options have not been set for the map, then default grid options are added
        //for the map otherwise the existing gridoptions are returned.
        //NOTE: Grid options are returned by value meaning a copy is always returned. Any changes made to the
        //grid options need to be -set- back on the map using SetGridOptions for the changes to persist.
        var gridOptions = GridOptionsEnvironment.Instance.GetGridOptions(
                                           gridOptionsMapView.Map);
        //Only return grid options if grid options have previously been set:
        var gridOptions2 = GridOptionsEnvironment.Instance.GetGridOptions(
                                           gridOptionsMapView.Map, false);
    Apply Symbology to a layer from a Layer file
      IEnumerable<FeatureLayer> featureLayers = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>()
        .Where(l => l.ShapeType == esriGeometryType.esriGeometryPoint);
      var layerFile = @"C:\Data\SDK\UniqueValuePointLayer.lyrx";
      foreach (var featureLayerToSymbolize in featureLayers)
        //Get the Layer Document from the lyrx file
        var lyrDocFromLyrxFile = new LayerDocument(layerFile);
        var cimLyrDoc = lyrDocFromLyrxFile.GetCIMLayerDocument();
        //Get the renderer from the layer file
        var rendererFromLayerFile = ((CIMFeatureLayer)cimLyrDoc.LayerDefinitions[0]).Renderer as CIMUniqueValueRenderer;
        //Apply the renderer to the feature layer
        //Note: If working with a raster layer, use the SetColorizer method.
        featureLayerToSymbolize?.SetRenderer(rendererFromLayerFile);
    Get a layer of a certain geometry type
      //Get an existing Layer. This layer has a symbol you want to use in a new layer.
      var lyr = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>()
              .Where(l => l.ShapeType == esriGeometryType.esriGeometryPoint).FirstOrDefault();
    Find a layer
      //Finds layers by name and returns a read only list of Layers
      IReadOnlyList<Layer> layers = map.FindLayers("cities", true);
      //Finds a layer using a URI.
      //The Layer URI you pass in helps you search for a specific layer in a map
      var lyrFindLayer = MapView.Active.Map.FindLayer("CIMPATH=map/u_s__states__generalized_.xml");
      //This returns a collection of layers of the "name" specified. You can use any Linq expression to query the collection.
      var lyrExists = MapView.Active.Map.GetLayersAsFlattenedList()
                         .OfType<FeatureLayer>().Any(f => f.Name == "U.S. States (Generalized)");
    Count the features selected on a layer
      var lyr = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault();
      var noFeaturesSelected = lyr.SelectionCount;
    Retrieve a table from its container
      var container = MapView.Active.Map;
      //the map standalone table collection
      var table = container.GetStandaloneTablesAsFlattenedList()
                              .FirstOrDefault(tbl => tbl.Name == "EarthquakeDamage");
      //or from a group layer
      var grp_layer = MapView.Active.Map.FindLayers("GroupLayer1").First() as GroupLayer;
      var table2 = grp_layer.FindStandaloneTables("EarthquakeDamage").First();
      //or         grp_layer.GetStandaloneTablesAsFlattenedList().First()
      //or         grp_layer.StandaloneTables.Where(...).First(), etc.
      //show the table in a table view
      //use FrameworkApplication.Current.Dispatcher.BeginInvoke if not on the UI thread
      FrameworkApplication.Panes.OpenTablePane(table2);
    Move a Standalone table
      //get the first group layer that has at least one table
      var grp_layer = MapView.Active.Map.GetLayersAsFlattenedList()
        .OfType<GroupLayer>().First(g => g.StandaloneTables.Count > 0);
      grp_layer.MoveStandaloneTable(grp_layer.StandaloneTables.First(), -1);
      //move the last table in the map standalone tables to a group
      //layer and place it at position 3. If 3 is invalid, the table
      //will be placed at the bottom of the target container
      //assumes the map has at least one standalone table...
      var table = map.StandaloneTables.Last();
      map.MoveStandaloneTable(table, grp_layer, 3);
      //move a table from a group layer to the map standalone tables
      //collection - assumes a table called 'Earthquakes' exists
      var table2 = grp_layer.FindStandaloneTables("Earthquakes").First();
      //move to the map container
      map.MoveStandaloneTable(table2, 0);//will be placed at the top
    Check SelectionSet Equality
      // get map selection
      var mapSelSet = MapView.Active.Map.GetSelection();
      // create a selectionSet
      var selDict = new Dictionary<MapMember, List<long>>();
      selDict.Add(featureLayer, new List<long> { 1506, 2696, 2246, 1647, 948 });
      var layerSelSet = ArcGIS.Desktop.Mapping.SelectionSet.FromDictionary(selDict);
      // test for equality - use Equals method
      var isEquals = mapSelSet.Equals(layerSelSet);
      // test for equality - use operators
      var equals = mapSelSet == layerSelSet;
      var notEquals = mapSelSet != layerSelSet;
    Get Elevation profile from the default ground surface
      // get the elevation profile for a polyline / set of polylines
      Polyline polyline = PolylineBuilderEx.CreatePolyline();
      MapPoint mapPoint = MapPointBuilderEx.CreateMapPoint(34, -118, SpatialReferences.WGS84);
      List<MapPoint> mapPoints = new List<MapPoint> { mapPoint };
      var result = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync([polyline]);
      if (result.Status == SurfaceZsResultStatus.Ok)
        var polylineZ = result.Polyline;
        // process the polylineZ
        // get the elevation profile for a set of points
        result = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(mapPoints);
    Get Elevation profile from a specific surface
      // find a specific elevation surface layer
      var eleLayer = MapView.Active.Map.GetElevationSurfaceLayers().FirstOrDefault(l => l.Name == "TIN");
      // use the specific elevation surface layer
      var zResult = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync([polyline], eleLayer);
      if (zResult.Status == SurfaceZsResultStatus.Ok)
        var polylineZ = zResult.Polyline;
      zResult = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(mapPoints, eleLayer);
    Interpolate a line between two points and calculate the elevation profile
      int numPoints = 20;//Or any number of points you want to interpolate
                         // use a specific elevation surface
      // use the default ground elevation surface
      MapPoint startPt = MapPointBuilderEx.CreateMapPoint(-130, 20, SpatialReferences.WGS84);
      MapPoint endPt = MapPointBuilderEx.CreateMapPoint(-100, 50, SpatialReferences.WGS84);
      var result = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(startPt, endPt, numPoints);
      result = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(startPt, endPt, numPoints, eleLayer);
    Show Elevation profile graph with a specific surface
      if (!MapView.Active.CanShowElevationProfileGraph())
        return;
      // set up the parameters
      var profileParams = new ElevationProfileParameters();
      profileParams.SurfaceLayer = eleLayer;
      profileParams.Densify = true;
      // show the elevation profile for a polyline using the params
      //Any line
      MapView.Active.ShowElevationProfileGraph([polyline], profileParams);
      // show the elevation profile for a set of points using the params
      //Some points
      MapView.Active.ShowElevationProfileGraph(mapPoints, profileParams);
    Show Elevation profile graph between two points
      int numPoints = 20;
        return;
      MapView.Active.ShowElevationProfileGraph(startPt, endPt, numPoints);
      var tinLayer = MapView.Active.Map.GetElevationSurfaceLayers().FirstOrDefault(l => l.Name == "TIN");
      // set up the params
      var elevProfileParams = new ElevationProfileParameters();
      elevProfileParams.SurfaceLayer = tinLayer;
      elevProfileParams.Densify = false;
      // show the elevation profile using the params
      MapView.Active.ShowElevationProfileGraph(startPt, endPt, numPoints, elevProfileParams);
    Show Elevation profile graph using an ElevationProfileResult
      var elevProfileResult = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(startPt, endPt, 10);
      if (elevProfileResult.Status != SurfaceZsResultStatus.Ok)
        return;
        return;
      // show the elevation profile using the result
      MapView.Active.ShowElevationProfileGraph(elevProfileResult);
    Zoom To a Point
        //Create a point
        var pt = MapPointBuilderEx.CreateMapPoint(x, y, spatialReference);
        //Buffer it - for purpose of zoom
        var poly = GeometryEngine.Instance.Buffer(pt, buffer_size);
        //do we need to project the buffer polygon?
        if (!mapView.Map.SpatialReference.IsEqual(poly.SpatialReference))
          //project the polygon
          poly = GeometryEngine.Instance.Project(poly, mapView.Map.SpatialReference);
        //Zoom - add in a delay for animation effect
        mapView.ZoomTo(poly, new TimeSpan(0, 0, 0, 3));
    Zoom To Bookmark by name
        //Get the first bookmark with the given name.
        var bookmark = mapView.Map.GetBookmarks().FirstOrDefault(b => b.Name == bookmarkName);
        if (bookmark == null)
          // Manage the error - bookmark not found
        //Zoom the view to the bookmark.
        mapView.ZoomTo(bookmark);
    Zoom Async To Bookmark by name
        mapView.ZoomToAsync(bookmark, TimeSpan.FromSeconds(2));
    Zoom To Visible Layers
        //Zoom to all visible layers in the map.
        var visibleLayers = mapView.Map.Layers.Where(l => l.IsVisible);
        mapView.ZoomTo(visibleLayers);
    Pan To Bookmark
        //Pan the view to the bookmark.
        mapView.PanTo(bookmark);
    Pan To Bookmark Async
      mapView.PanToAsync(bookmark, TimeSpan.FromSeconds(2));
    Pan To Visible Layers
        //Pan to all visible layers in the map.
        mapView.PanTo(visibleLayers);
    Get the active map's name
      //Return the name of the map currently displayed in the active map view.
      var result = mapView.Map.Name;
      // Use the result variable as needed
    Clear all selection in an Active map
        mapView.Map?.SetSelection(null);
    Calculate Selection tolerance in map units
      //Selection tolerance for the map in pixels
      var selectionTolerance = SelectionEnvironment.SelectionTolerance;
        //Get the map center
        var mapExtent = mapView.Map.GetDefaultExtent();
        var mapPoint = mapExtent.Center;
        //Map center as screen point
        var screenPoint = mapView.MapToScreen(mapPoint);
        //Add selection tolerance pixels to get a "radius".
        var radiusScreenPoint = new System.Windows.Point(screenPoint.X + selectionTolerance, screenPoint.Y);
        var radiusMapPoint = mapView.ScreenToMap(radiusScreenPoint);
        //Calculate the selection tolerance distance in map units.
        var searchRadius = GeometryEngine.Instance.Distance(mapPoint, radiusMapPoint);
    Select all feature layers in TOC
      //Zoom to the selected layers in the TOC
      var featureLayers = mapView.Map.Layers.OfType<FeatureLayer>();
      mapView.SelectLayers(featureLayers.ToList());
    Flash selected features
        //Get the selected features from the map and filter out the standalone table selection.
        var selectedFeatures = mapView.Map.GetSelection();
        //Flash the collection of features.
        mapView.FlashFeature(selectedFeatures);
    Display Table pane for Map Member
      mapMember = MapView.Active.Map.GetLayersAsFlattenedList().OfType<MapMember>().FirstOrDefault();
      //Gets or creates the CIMMapTableView for a MapMember.
      var mapTableView = FrameworkApplication.Panes.GetMapTableView(mapMember);
      //Configure the table view
      mapTableView.DisplaySubtypeDomainDescriptions = false;
      mapTableView.SelectionMode = false;
      mapTableView.ShowOnlyContingentValueFields = true;
      mapTableView.HighlightInvalidContingentValueFields = true;
      //Open the table pane using the configured tableView. If a table pane is already open it will be activated.
      //You must be on the UI thread to call this function.
      var tablePane = FrameworkApplication.Panes.OpenTablePane(mapTableView);
    Mask feature
        //Get the layer to be masked
        var lineLyrToBeMasked = mapView.Map.Layers.FirstOrDefault(lyr => lyr.Name == "TestLine") as FeatureLayer;
        //Get the layer's definition
        var lyrDefn = lineLyrToBeMasked.GetDefinition();
        //Create an array of Masking layers (polygon only)
        //Set the LayerMasks property of the Masked layer
        lyrDefn.LayerMasks = ["CIMPATH=map3/testpoly.xml"];
        //Re-set the Masked layer's definition
        lineLyrToBeMasked.SetDefinition(lyrDefn);
    Create a new bookmark using the active map view
        //Adding a new bookmark using the active view.
        mapView.Map.AddBookmark(mapView, bookmarkName);
    Add New Bookmark from CIMBookmark
        //Set properties for Camera
        CIMViewCamera cimCamera = new()
          X = camera.X,
          Y = camera.Y,
          Z = camera.Z,
          Scale = camera.Scale,
          Pitch = camera.Pitch,
          Heading = camera.Heading,
          Roll = camera.Roll
        //Create new CIM bookmark and populate its properties
        var cimBookmark = new CIMBookmark() { Camera = cimCamera, Name = cameraName, ThumbnailImagePath = "" };
        //Add a new bookmark for the active map.
        mapView.Map.AddBookmark(cimBookmark);
    Get Map Bookmarks
        //Return the collection of bookmarks for the map.
        var result = mapView.Map.GetBookmarks();
        // Use the bookmarks (if any)
    Move Bookmark to the Top
        var map = mapView.Map;
        //Find the first bookmark with the name
        var bookmark = map.GetBookmarks().FirstOrDefault(b => b.Name == bookmarkName);
          //Bookmark not found
        //Move the bookmark to the top of the list
        map.MoveBookmark(bookmark, 0);
    Rename Bookmark
      oldBookmark = mapView.Map.GetBookmarks().FirstOrDefault(b => b.Name == bookmarkName);
      oldBookmark.Rename(newBookmarkName);
    Remove bookmark with a given name
        //Remove the bookmark
        mapView.Map.RemoveBookmark(bookmark);
    Set Animation Length
      var animation = mapView.Map.Animation;
      var duration = animation.Duration;
      if (duration == TimeSpan.Zero)
        return;
      var factor = length.TotalSeconds / duration.TotalSeconds;
      animation.ScaleDuration(factor);
    Scale Animation
      if (duration == TimeSpan.Zero || duration <= afterTime)
        // Nothing to scale, leave
      var factor = length.TotalSeconds / (duration.TotalSeconds - afterTime.TotalSeconds);
      animation.ScaleDuration(afterTime, duration, factor);
    Camera Keyframes
      var cameraTrack = animation.Tracks.OfType<CameraTrack>().First(); //There will always be only 1 CameraTrack in the animation.
      var result = cameraTrack.Keyframes.OfType<CameraKeyframe>().ToList();
      //Use the camera keyframes (if any)
    Interpolate Camera
      //Return the collection representing the camera for each frame in animation.
        var cameras = new List<Camera>();
        //We will use ticks here rather than milliseconds to get the highest precision possible.
        var ticksPerFrame = Convert.ToInt64(animation.Duration.Ticks / (animation.NumberOfFrames - 1));
        for (int i = 0; i < animation.NumberOfFrames; i++)
          var time = TimeSpan.FromTicks(i * ticksPerFrame);
          //Because of rounding for ticks the last calculated time may be greater than the duration.
          if (time > animation.Duration)
            time = animation.Duration;
          cameras.Add(mapView.Animation.GetCameraAtTime(time));
        // Use cameras
    Interpolate Time
      //Return the collection representing the map time for each frame in animation.
        var timeRanges = new List<TimeRange>();
          timeRanges.Add(mapView.Animation.GetCurrentTimeAtTime(time));
        // Use timeRanges;
    Interpolate Range
        var ranges = new List<ArcGIS.Desktop.Mapping.Range>();
          //Because of rounding for ticks the last calculated time may be greeting than the duration.
          ranges.Add(mapView.Animation.GetCurrentRangeAtTime(time));
        // Use ranges
    Create Camera Keyframe
      cameraTrack.CreateKeyframe(mapView.Camera, atTime, AnimationTransition.FixedArc);
    Create Time Keyframe
      var timeTrack = animation.Tracks.OfType<TimeTrack>().First(); //There will always be only 1 TimeTrack in the animation.
      timeTrack.CreateKeyframe(mapView.Time, atTime, AnimationTransition.Linear);
    Create Range Keyframe
      var rangeTrack = animation.Tracks.OfType<RangeTrack>().First(); //There will always be only 1 RangeTrack in the animation.
      rangeTrack.CreateKeyframe(range, atTime, AnimationTransition.Linear);
    Create Layer Keyframe
      var layerTrack = animation.Tracks.OfType<LayerTrack>().First(); //There will always be only 1 LayerTrack in the animation.
      layerTrack.CreateKeyframe(layer, atTime, true, transparency, AnimationTransition.Linear);
    EsriHttpClient: Get a Service Layer and Add it to Pro
      UriBuilder searchURL = new UriBuilder(ArcGISPortalManager.Current.GetActivePortal().PortalUri)
        Path = "sharing/rest/search"
      string layers = "(type:\"Map Service\" OR type:\"Image Service\" OR type:\"Feature Service\" OR type:\"WMS\" OR type:\"KML\")";
      //any public layer content
      searchURL.Query = string.Format("q={0}&f=json", layers);
      EsriHttpClient httpClient = new EsriHttpClient();
      var searchResponse = httpClient.Get(searchURL.Uri.ToString());
      dynamic resultItems = JObject.Parse(await searchResponse.Content.ReadAsStringAsync());
      long numberOfTotalItems = resultItems.total.Value;
      if (numberOfTotalItems == 0)
        return;
      List<dynamic> resultItemList = new List<dynamic>();
      resultItemList.AddRange(resultItems.results);
      //get the first result
      dynamic item = resultItemList[0];
      string itemID = item.id;
      Item currentItem = ItemFactory.Instance.Create(itemID, ItemFactory.ItemType.PortalItem);
      var mapView = MapView.Active;
      if (mapView == null)
        return;
        //Create a LayerCreationParam
        var layerParam = new LayerCreationParams(currentItem);
        // if we have an item that can be turned into a layer
        // add it to the map
        if (LayerFactory.Instance.CanCreateLayerFrom(currentItem))
          LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParam, mapView.Map);
    Retrieve layers
      // find the first TIN layer
      tinLayer = mapView.Map.GetLayersAsFlattenedList().OfType<TinLayer>().FirstOrDefault();
      // find the first Terrain layer
      terrainLayer = mapView.Map.GetLayersAsFlattenedList().OfType<TerrainLayer>().FirstOrDefault();
      // find the first LAS dataset layer
      lasDatasetLayer = mapView.Map.GetLayersAsFlattenedList().OfType<LasDatasetLayer>().FirstOrDefault();
      // find the first surface layer
      surfaceLayer = mapView.Map.GetLayersAsFlattenedList().OfType<SurfaceLayer>().FirstOrDefault();
    Create a TinLayer with renderers
      var tinCP_renderers = new TinLayerCreationParams(tinDataset)
        Name = "My TIN layer",
        IsVisible = true
      // define the node renderer - use defaults
      var node_rd = new TinNodeRendererDefinition();
      // define the face/surface renderer
      var face_rd = new TinFaceClassBreaksRendererDefinition();
      face_rd.ClassificationMethod = ClassificationMethod.NaturalBreaks;
      // accept default color ramp, breakCount
      // set up the renderer dictionary
      var rendererDict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>
      { SurfaceRendererTarget.Points, node_rd },
      { SurfaceRendererTarget.Surface, face_rd }
      // assign the dictionary to the creation params
      tinCP_renderers.RendererDefinitions = rendererDict;
        // create the layer
        var tinLayer_rd = LayerFactory.Instance.CreateLayer<TinLayer>(tinCP_renderers, mapView.Map);
    Get Line of Sight
      tinLayer = null;
      MapPoint observerPoint = null;
      MapPoint targetPoint = null;
      CIMPointSymbol obstructionPointSymbol = null;
      CIMLineSymbol visibleLineSymbol = null;
      CIMLineSymbol invisibleLineSymbol = null;
      var losParams = new LineOfSightParams();
      losParams.ObserverPoint = observerPoint;
      losParams.TargetPoint = targetPoint;
      // add offsets if appropriate
      // losParams.ObserverHeightOffset = observerOffset;
      // losParams.TargetHeightOffset = targerOffset;
      // add obstruction feature class if appropriate (multipatch)
      //losParams.ObstructionsMultipatchFeatureClass = obsFeatureClass;
      // set output spatial reference
      losParams.OutputSpatialReference = mapView.Map.SpatialReference;
      LineOfSightResult results = null;
      try
          if (tinLayer.CanGetLineOfSight(losParams))
            results = tinLayer.GetLineOfSight(losParams);
      catch (Exception)
        // handle exception
      if (results != null)
        bool targetIsVisibleFromObserverPoint = results.IsTargetVisibleFromObserverPoint;
        //These properties are not used. They will always be false
        // results.IsTargetVisibleFromVisibleLine;
        // results.IsTargetVisibleFromInvisibleLine;
        if (results.VisibleLine != null)
          mapView.AddOverlay(results.VisibleLine, visibleLineSymbol.MakeSymbolReference());
        if (results.InvisibleLine != null)
          mapView.AddOverlay(results.VisibleLine, invisibleLineSymbol.MakeSymbolReference());
        if (results.ObstructionPoint != null)
          mapView.AddOverlay(results.ObstructionPoint, obstructionPointSymbol.MakeSymbolReference());
    Bulk Graphics creation
      //Point Feature layer to convert into graphics
      var lyr = mapView?.Map?.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(s => s.ShapeType == esriGeometryType.esriGeometryPoint);
      if (lyr == null)
        return;
        //Point symbol for graphics
        var pointSymbol = SymbolFactory.Instance.ConstructPointSymbol(CIMColor.CreateRGBColor(100, 255, 40), 10, SimpleMarkerStyle.Circle);
        //Collection to hold the point graphics
        var listGraphicElements = new List<CIMGraphic>();
        //Iterate through each point feature in the feature layer
        using (RowCursor rows = lyr.Search()) //execute
          int i = 0;
          while (rows.MoveNext())
            using var feature = rows.Current as Feature;
            //Create a point graphic for the feature
            var crimePt = feature.GetShape() as MapPoint;
            if (crimePt != null)
              var cimGraphicElement = new CIMPointGraphic
                Location = crimePt, //MapPoint
                Symbol = pointSymbol.MakeSymbolReference()
              //Add the point feature to the collection
              listGraphicElements.Add(cimGraphicElement);
              i++;
        //Magic happens...Add all the features to the Graphics layer
        graphicsLayer.AddElements(listGraphicElements);
    Get the active map's labeling engine - Maplex or Standard labeling engine
      var map = MapView.Active?.Map;
      if (map == null)
        return;
        //Get the active map's definition - CIMMap.
        var cimMap = map.GetDefinition();
        //Get the labeling engine from the map definition
        CIMGeneralPlacementProperties labelEngine = cimMap.GeneralPlacementProperties;
    Change the active map's labeling engine from Standard to Maplex or vice versa
      if (map == null)
        return;
        var cimGeneralPlacement = cimMap.GeneralPlacementProperties;
        if (cimGeneralPlacement is CIMMaplexGeneralPlacementProperties)
          //Current labeling engine is Maplex labeling engine
          //Create a new standard label engine properties
          var cimStandardPlacementProperties = new CIMStandardGeneralPlacementProperties();
          //Set the CIMMap's GeneralPlacementProperties to the new label engine
          cimMap.GeneralPlacementProperties = cimStandardPlacementProperties;
        else
          //Current labeling engine is Standard labeling engine
          //Create a new Maplex label engine properties
          var cimMaplexGeneralPlacementProperties = new CIMMaplexGeneralPlacementProperties();
          cimMap.GeneralPlacementProperties = cimMaplexGeneralPlacementProperties;
        //Set the map's definition
        map.SetDefinition(cimMap);
    Modify the Placement/Position of labels - Line geometry
      if (map == null)
        return;
        var lyrDefn = featureLayer.GetDefinition() as CIMFeatureLayer;
        //Get the label classes - we need the first one
        var listLabelClasses = lyrDefn.LabelClasses.ToList();
        var theLabelClass = listLabelClasses.FirstOrDefault();
        //Modify label Placement
        //Check if the label engine is Maplex or standard.
            map.GetDefinition().GeneralPlacementProperties;
        if (labelEngine is CIMStandardGeneralPlacementProperties)
          var lineLablePosition = new CIMStandardLineLabelPosition
            Perpendicular = true,
            Parallel = false,
            ProduceCurvedLabels = false,
            Horizontal = false,
            OnTop = true
          theLabelClass.StandardLabelPlacementProperties.LineLabelPosition =
              lineLablePosition;
        else //Current labeling engine is Maplex labeling engine
          theLabelClass.MaplexLabelPlacementProperties.LinePlacementMethod =
                        MaplexLinePlacementMethod.CenteredPerpendicularOnLine;
          theLabelClass.MaplexLabelPlacementProperties.LineFeatureType =
                        MaplexLineFeatureType.General;
        //theLabelClass.MaplexLabelPlacementProperties.LinePlacementMethod = MaplexLinePlacementMethod.CenteredPerpendicularOnLine;
        lyrDefn.LabelClasses = listLabelClasses.ToArray(); //Set the labelClasses back
        featureLayer.SetDefinition(lyrDefn); //set the layer's definition
    Modify the Placement/Position of labels - Polygon geometry
      if (map == null)
        return;
        CIMGeneralPlacementProperties labelEngine = map.GetDefinition().GeneralPlacementProperties;
          //Current labeling engine is Standard Labeling engine
          theLabelClass.StandardLabelPlacementProperties.PolygonPlacementMethod =
                   StandardPolygonPlacementMethod.AlwaysHorizontal;
          theLabelClass.StandardLabelPlacementProperties.PlaceOnlyInsidePolygon = true;
        else
          theLabelClass.MaplexLabelPlacementProperties.PolygonFeatureType =
                                   MaplexPolygonFeatureType.LandParcel;
          theLabelClass.MaplexLabelPlacementProperties.AvoidPolygonHoles = true;
          theLabelClass.MaplexLabelPlacementProperties.PolygonPlacementMethod =
                              MaplexPolygonPlacementMethod.HorizontalInPolygon;
          theLabelClass.MaplexLabelPlacementProperties.CanPlaceLabelOutsidePolygon = true;
                                             //set the label's visiblity
        featureLayer.SetLabelVisibility(true);
    Modify Orientation of a label using the MaplexEngine - Points and Polygon geometry
      if (map == null)
        return;
          return;
        //Modify label Orientation
        theLabelClass.MaplexLabelPlacementProperties.GraticuleAlignment = true;
        theLabelClass.MaplexLabelPlacementProperties.GraticuleAlignmentType = MaplexGraticuleAlignmentType.Curved;
    Modify Orientation of a label using the MaplexEngine - Line geometry
      if (map == null)
        return;
          return;
        theLabelClass.MaplexLabelPlacementProperties.AlignLabelToLineDirection = true;
    Modify label Rotation - Point geometry
      if (map == null)
        return;
          return;
        //Modify label Rotation
        CIMMaplexRotationProperties rotationProperties = new CIMMaplexRotationProperties
          Enable = true, //Enable rotation
          RotationField = "ELEVATION", //Field that is used to define rotation angle
          AdditionalAngle = 15, //Additional rotation
          RotationType = MaplexLabelRotationType.Arithmetic,
          AlignmentType = MaplexRotationAlignmentType.Perpendicular,
          AlignLabelToAngle = true
        theLabelClass.MaplexLabelPlacementProperties.RotationProperties = rotationProperties;
    Spread labels across Polygon geometry
      if (map == null)
        return;
          return;
        //Spread Labels (words and characters to fill feature)
        // Spread words to fill feature
        theLabelClass.MaplexLabelPlacementProperties.SpreadWords = true;
        //Spread Characters to a fixed limit of 50%
        theLabelClass.MaplexLabelPlacementProperties.SpreadCharacters = true;
        theLabelClass.MaplexLabelPlacementProperties.MaximumCharacterSpacing = 50.0;
    Modify label's Leader Line Anchor point properties - Polygon geometry
      if (map == null)
        return;
          return;
        //If TextSymbol is a call-out the leader line anchor point can be modified
        theLabelClass.MaplexLabelPlacementProperties.PolygonAnchorPointType = MaplexAnchorPointType.Perimeter;
        lyrDefn.LabelClasses = [.. listLabelClasses]; //Set the labelClasses back
    Create a Scene Layer
      if (map == null)
        return;
        //Create with initial visibility set to false. Add to current scene
        var createparams = new LayerCreationParams(new Uri(sceneLayerUrl, UriKind.Absolute))
          IsVisible = false
        //cast to specific type of scene layer being created - in this case FeatureSceneLayer
        var sceneLayer = LayerFactory.Instance.CreateLayer<Layer>(
                 createparams, map) as FeatureSceneLayer;
        //or...specify the cast directly
        var sceneLayer2 = LayerFactory.Instance.CreateLayer<FeatureSceneLayer>(
                 createparams, map);
        //ditto for BuildingSceneLayer, PointCloudSceneLayer, IntegratedMeshSceneLayer
    Get BuildingDisciplineSceneLayer Discipline
      var bsl_discipline = MapView.Active.Map.GetLayersAsFlattenedList().OfType<BuildingDisciplineSceneLayer>().FirstOrDefault(l => l.Name == "Architectural");
      var disciplineName = bsl_discipline.GetDiscipline();
    Enumerate the Discipline Layers from a Building SceneLayer
      var bldgLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<BuildingSceneLayer>().First();
      var disciplines = new Dictionary<string, BuildingDisciplineSceneLayer>();
      //A Building layer has two children - Overview and FullModel
      //Overview is a FeatureSceneLayer
      //Full Model is a BuildingDisciplineSceneLayer that contains the disciplines
      var fullModel = bldgLayer.FindLayers("Full Model").First()
                                     as BuildingDisciplineSceneLayer;
      //collect information on the disciplines
      var name = fullModel.Name;
      var discipline = fullModel.GetDiscipline();
      //etc
      //TODO - use collected information
      disciplines.Add(discipline, fullModel);
      //Discipline layers are composite layers too
      foreach (var childDiscipline in fullModel.Layers
                          .OfType<BuildingDisciplineSceneLayer>())
        //Discipline layers can also contain FeatureSceneLayers that render the
        //individual full model contents
        var content_names = string.Join(", ", childDiscipline.Layers
             .OfType<FeatureSceneLayer>().Select(fl => fl.Name));
        // Recursively call this "function" to go deeper
    Name of BuildingSceneLayer
      bsl = MapView.Active.Map.GetLayersAsFlattenedList()
            .OfType<BuildingSceneLayer>().FirstOrDefault();
      var scenelayerName = bsl.Name;
    Determine if a FeatureSceneLayer supports editing
      featSceneLayer = MapView.Active.Map.GetLayersAsFlattenedList()
                         .OfType<FeatureSceneLayer>().FirstOrDefault();
      if (!featSceneLayer.HasAssociatedFeatureService ||
          !featSceneLayer.IsEditable)
        //not supported - exit the function
      //TODO continue editing here...
    Name of FeatureSceneLayer
      var scenelayerName = featSceneLayer?.Name;
    Use MapView Selection SelectFeaturesEx or GetFeaturesEx
      var sname = featSceneLayer.Name;
        return;
        //Select all features within the current map view
        var sz = mapView.GetViewSize();
        var c_ll = new Coordinate2D(0, 0);
        var c_ur = new Coordinate2D(sz.Width, sz.Height);
        //Use screen coordinates for 3D selection on MapView
        var env = EnvelopeBuilderEx.CreateEnvelope(c_ll, c_ur);
        //HasAssociatedFeatureService does not matter for SelectFeaturesEx
        //or GetFeaturesEx
        var result = mapView.SelectFeaturesEx(env);
        //var result = mapView.GetFeaturesEx(env);
        //The list of object ids from SelectFeaturesEx
        var oids1 = result.ToDictionary().Where(kvp => kvp.Key.Name == sname).First().Value;
        //TODO - use the object ids
        mapView.Map.ClearSelection();
    Use Select or Search with a Spatial Query
        return;
        if (!featSceneLayer.HasAssociatedFeatureService)
          return;//no search or select
        var map_pt1 = mapView.ClientToMap(new System.Windows.Point(0, sz.Height));
        var map_pt2 = mapView.ClientToMap(new System.Windows.Point(sz.Width, 0));
        //Convert to an envelope
        var temp_env = EnvelopeBuilderEx.CreateEnvelope(map_pt1, map_pt2, mapView.Map.SpatialReference);
        //Project if needed to the layer spatial ref
        SpatialReference sr = null;
        using (var fc = featSceneLayer.GetFeatureClass())
        using (var fdef = fc.GetDefinition())
          sr = fdef.GetSpatialReference();
        var env = GeometryEngine.Instance.Project(temp_env, sr) as Envelope;
        //Set up a query filter
        var sf = new SpatialQueryFilter()
          FilterGeometry = env,
          SpatialRelationship = SpatialRelationship.Intersects,
          SubFields = "*"
        //Select against the feature service
        var select = featSceneLayer.Select(sf);
        if (select.GetCount() > 0)
          //enumerate over the selected features
          using (var rc = select.Search())
            while (rc.MoveNext())
              using (var feature = rc.Current as Feature)
                oid = feature.GetObjectID();
                //etc.
    Find all Stream Layers that are Track Aware
      var trackAwareLayers = MapView.Active.Map.GetLayersAsFlattenedList()
                                 .OfType<StreamLayer>().Where(sl => sl.IsTrackAware)?.ToList();
    Get a Voxel Layer from the TOC
      //Get selected layer if a voxel layer is selected
      voxelLayer = MapView.Active.GetSelectedLayers().OfType<VoxelLayer>().FirstOrDefault();
      if (voxelLayer == null)
        //just get the first voxel layer in the TOC
        voxelLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<VoxelLayer>().FirstOrDefault();
          return;
    Requirements
