public IReadOnlyList<Layer> GetSelectedLayers()
Public Function GetSelectedLayers() As IReadOnlyList(Of Layer)
Return Value
The collection of layers selected in the TOC.
// group a set of layers selected in the TOC
var selectedLayers = mapView.GetSelectedLayers();
if (map.CanGroupMapMembers(selectedLayers))
map.GroupMapMembers(selectedLayers, "Group1");
// ungroup a groupLayer
if (map.CanUngroupLayer(groupLayer))
map.UngroupLayer(groupLayer);
// get the layers selected in the TOC
var selectedLayers = MapView.Active.GetSelectedLayers();
// get the standalonetables elected in the TOC
var selectedTables = MapView.Active.GetSelectedStandaloneTables();
var selectedMMs = new List<MapMember>(selectedLayers);
selectedMMs.AddRange(selectedTables);
// create the LayerDocument
LayerDocument layerDocument = new LayerDocument(selectedMMs);
await QueuedTask.Run(() => layerDocument.Save(@"c:\Data\MyLayerDocument.lyrx"));
string mapPaneCaption = "USNationalParks";
IMapPane mapViewPane = FrameworkApplication.Panes.OfType<IMapPane>().FirstOrDefault((p) => p.Caption == mapPaneCaption);
mapView = null;
if (mapViewPane != null)
// activate the MapPane
(mapViewPane as Pane).Activate();
if (mapView != null)
// get the layers selected in the map's TOC
//Zoom to the selected layers in the TOC
mapView.ZoomToAsync(selectedLayers);
//Pan to the selected layers in the TOC
mapView.PanToAsync(selectedLayers);
//Get selected layer if a voxel layer is selected
voxelLayer = MapView.Active.GetSelectedLayers().OfType<VoxelLayer>().FirstOrDefault();
if (voxelLayer == null)
//just get the first voxel layer in the TOC
voxelLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<VoxelLayer>().FirstOrDefault();
return;
