ArcGIS.Desktop.Mapping Namespace / KnowledgeGraphMappingExtensions Class / SetShowRootNodes Method
Value indicating whether to display root nodes.
Example
    Sets whether root nodes are displayed for the link chart map view. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Shared Sub SetShowRootNodes( _
       ByVal mapView As MapView, _
       ByVal showRootNodes As Boolean _
    public static void SetShowRootNodes(
       MapView mapView,
       bool showRootNodes
    Parameters
    mapView
    showRootNodes
    Exceptions
    ExceptionDescription
    Map cannot be null.
    Map is not a link chart.
    Example
    Toggle Root Node Display
      var val = MapView.Active.GetShowRootNodes();
      await QueuedTask.Run(() =>
        MapView.Active.SetShowRootNodes(!val);
    Requirements
    ArcGIS Pro version: 3.4 or higher.
