Public Function ScreenToMap( _ ByVal screenPoint As Point _ ) As MapPoint
public MapPoint ScreenToMap( Point screenPoint )
Parameters
- screenPoint
- The point value in screen coordinates.
Return Value
The converted point in map coordinates.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
//Selection tolerance for the map in pixels
var selectionTolerance = SelectionEnvironment.SelectionTolerance;
// Note: Needs QueuedTask to run
//Get the map center
var mapExtent = MapView.Active.Map.GetDefaultExtent();
var mapPoint = mapExtent.Center;
//Map center as screen point
var screenPoint = MapView.Active.MapToScreen(mapPoint);
//Add selection tolerance pixels to get a "radius".
var radiusScreenPoint = new System.Windows.Point(screenPoint.X + selectionTolerance, screenPoint.Y);
var radiusMapPoint = MapView.Active.ScreenToMap(radiusScreenPoint);
//Calculate the selection tolerance distance in map units.
var searchRadius = GeometryEngine.Instance.Distance(mapPoint, radiusMapPoint);
