ArcGIS.Desktop.Mapping Namespace / MapView Class / GetViewSize Method
Example
    GetViewSize Method (MapView)
    Returns the current size of the view.
    Syntax
    Public Function GetViewSize() As Size
    public Size GetViewSize()
    Return Value
    The current size of the view.
    Example
    Use MapView Selection SelectFeaturesEx or GetFeaturesEx
      var sname = featSceneLayer.Name;
      // Note: call within QueuedTask.Run()
        //Select all features within the current map view
        var sz = MapView.Active.GetViewSize();
        var c_ll = new Coordinate2D(0, 0);
        var c_ur = new Coordinate2D(sz.Width, sz.Height);
        //Use screen coordinates for 3D selection on MapView
        var env = EnvelopeBuilderEx.CreateEnvelope(c_ll, c_ur);
        //HasAssociatedFeatureService does not matter for SelectFeaturesEx
        //or GetFeaturesEx
        var result = MapView.Active.SelectFeaturesEx(env);
        //var result = MapView.Active.GetFeaturesEx(env);
        //The list of object ids from SelectFeaturesEx
        var oids1 = result.ToDictionary().Where(kvp => kvp.Key.Name == sname).First().Value;
        //TODO - use the object ids
        MapView.Active.Map.ClearSelection();
    Use Select or Search with a Spatial Query
      if (!featSceneLayer.HasAssociatedFeatureService)
        return;//no search or select
      var map_pt1 = MapView.Active.ClientToMap(new System.Windows.Point(0, sz.Height));
      var map_pt2 = MapView.Active.ClientToMap(new System.Windows.Point(sz.Width, 0));
      //Convert to an envelope
      var temp_env = EnvelopeBuilderEx.CreateEnvelope(map_pt1, map_pt2, MapView.Active.Map.SpatialReference);
      //Project if needed to the layer spatial ref
      SpatialReference sr = null;
      using (var fc = featSceneLayer.GetFeatureClass())
      using (var fdef = fc.GetDefinition())
        sr = fdef.GetSpatialReference();
      var env = GeometryEngine.Instance.Project(temp_env, sr) as Envelope;
      //Set up a query filter
      var sf = new SpatialQueryFilter()
        FilterGeometry = env,
        SpatialRelationship = SpatialRelationship.Intersects,
        SubFields = "*"
      //Select against the feature service
      var select = featSceneLayer.Select(sf);
      if (select.GetCount() > 0)
        //enumerate over the selected features
        using (var rc = select.Search())
          while (rc.MoveNext())
            using (var feature = rc.Current as Feature)
              oid = feature.GetObjectID();
              //etc.
    Requirements
