public static MapMemberIDSet GetRootNodes( MapView mapView )
Public Shared Function GetRootNodes( _ ByVal mapView As MapView _ ) As MapMemberIDSet
Parameters
- mapView
| Exception | Description |
| System.ArgumentNullException | Map cannot be null. |
| System.ArgumentException | Map is not a link chart. |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
var rootNodesMapView = MapView.Active;
if (rootNodesMapView == null)
return;
await QueuedTask.Run(() =>
MapMemberIDSet rootNodes = rootNodesMapView.GetRootNodes();
var rootNodeDict = rootNodes.ToDictionary();
// rootNodeDict is a Dictionary<MapMember, List<long>>
// access a particular mapMember in the Dictionary
if (rootNodeDict.ContainsKey(mapMember))
var oids = rootNodeDict[mapMember];
// OR iterate through the dictionary
foreach (var (mm, oids) in rootNodeDict)
// do something
