ArcGIS.Desktop.Mapping Namespace / MapView Class / ZoomToSelectedAsync Method
The amount of time to navigate the view to the new camera position. If null it uses the default navigation duration.
Indicates if the Pitch and Heading should remain the same after the navigation is completed. If false the Heading will be set to 15.0 and the Pitch will be set to -60.0. This parameter only effects 3D views.
Example
    Zoom the view to the extent of the selected features in the map or scene.
    Syntax
    Public Function ZoomToSelectedAsync( _
       Optional ByVal duration As Nullable(Of TimeSpan), _
       Optional ByVal maintainViewDirection As Boolean _
    ) As Task(Of Boolean)
    Parameters
    duration
    Return Value
    True if the navigation is completed, false if it was interrupted by another view navigation.
    Example
    Zoom Async To Selected Features with a timespan
      //Zoom to the map's selected features.
      mapView.ZoomToSelectedAsync(TimeSpan.FromSeconds(2));
    Requirements
