ArcGIS.Desktop.Mapping Namespace / MapView Class / CanShowElevationProfileGraph Method
Example
    Checks to see if an elevation profile can be displayed.
    Syntax
    Public Function CanShowElevationProfileGraph() As Boolean
    public bool CanShowElevationProfileGraph()
    Return Value
    True if the mapView supports showing an elevation profile. Elevation profiles can be displayed for scenes only.
    Example
    Show Elevation profile graph with the default ground surface
        if (!MapView.Active.CanShowElevationProfileGraph())
            return;
        // show the elevation profile for a polyline
        // use the default ground surface layer
        Polyline polyline = PolylineBuilderEx.CreatePolyline();
        MapView.Active.ShowElevationProfileGraph([polyline]);
        // show the elevation profile for a set of points
        //Some points
        MapPoint mapPoint = MapPointBuilderEx.CreateMapPoint(34, -118, SpatialReferences.WGS84);
        List<MapPoint> mapPoints = new List<MapPoint> { mapPoint };
        MapView.Active.ShowElevationProfileGraph(mapPoints);
    Show Elevation profile graph with a specific surface
            return;
        // use a specific elevation surface
        var eleLayer = MapView.Active.Map.GetElevationSurfaceLayers().FirstOrDefault(l => l.Name == "TIN");
        // set up the parameters
        var profileParams = new ElevationProfileParameters();
        profileParams.SurfaceLayer = eleLayer;
        profileParams.Densify = true;
        // show the elevation profile for a polyline using the params
        //Any line
        MapView.Active.ShowElevationProfileGraph([polyline], profileParams);
        // show the elevation profile for a set of points using the params
        //Some points
        MapView.Active.ShowElevationProfileGraph(mapPoints, profileParams);
    Show Elevation profile graph between two points
        int numPoints = 20;
            return;
        // use the default ground elevation surface
        MapPoint startPt = MapPointBuilderEx.CreateMapPoint(-130, 20, SpatialReferences.WGS84);
        MapPoint endPt = MapPointBuilderEx.CreateMapPoint(-100, 50, SpatialReferences.WGS84);
        MapView.Active.ShowElevationProfileGraph(startPt, endPt, numPoints);
        // find a specific elevation surface layer
        var tinLayer = MapView.Active.Map.GetElevationSurfaceLayers().FirstOrDefault(l => l.Name == "TIN");
        // set up the params
        var elevProfileParams = new ElevationProfileParameters();
        elevProfileParams.SurfaceLayer = tinLayer;
        elevProfileParams.Densify = false;
        // show the elevation profile using the params
        MapView.Active.ShowElevationProfileGraph(startPt, endPt, numPoints, elevProfileParams);
    Show Elevation profile graph using an ElevationProfileResult
        var elevProfileResult = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(startPt, endPt, 10);
        if (elevProfileResult.Status != SurfaceZsResultStatus.Ok)
            return;
            return;
        // show the elevation profile using the result
        MapView.Active.ShowElevationProfileGraph(elevProfileResult);
    Requirements
    ArcGIS Pro version: 3.5 or higher.
