ArcGIS.Desktop.Mapping Namespace / MapView Class / PanTo Method
    PanTo Method
    Overload List
    OverloadDescription
    Pan the view to a camera position. This method must be called on the MCT. Use QueuedTask.Run.
    Pan the view to the position defined in a bookmark. This method must be called on the MCT. Use QueuedTask.Run.
    Pan the view to the extent defined by a geometry. This method must be called on the MCT. Use QueuedTask.Run.
    Pan the view to the extent of a layer. This method must be called on the MCT. Use QueuedTask.Run.
    Pan the view to the extent of one or more layers. This method must be called on the MCT. Use QueuedTask.Run.
    Pan the view to the extent of a feature. This method must be called on the MCT. Use QueuedTask.Run.
    Pan the view to the extent of one or more features. This method must be called on the MCT. Use QueuedTask.Run.
    Zoom the view to the extent of one or more features. This method must be called on the MCT. Use QueuedTask.Run.
    Requirements
