ArcGIS.Desktop.Mapping Namespace / MapView Class / PanTo Method / PanTo(Geometry,Nullable<TimeSpan>) Method
The geometry defining the extent in which to pan.
The amount of time to navigate the view to the new camera position. If null it uses the default navigation duration.
Example
    Pan the view to the extent defined by a geometry. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function PanTo( _
       ByVal geometry As Geometry, _
       Optional ByVal duration As Nullable(Of TimeSpan) _
    ) As Boolean
    Parameters
    geometry
    duration
    Return Value
    True if the navigation is completed, false if it was interrupted by another view navigation.
    Exceptions
    ExceptionDescription
    Remarks
    Pan in 2D maintains the current camera scale and heading and modifies the X and Y position. Pan in 3D maintains the current camera pitch and heading and modifies the X and Y position. If the geometry's spatial reference is in a different spatial reference than the map this method projects the geometry into the spatial reference of the map.
    Example
    Pan To an Extent
      // Note: Needs QueuedTask to run
        //Pan the view to a given extent.
        envelope = EnvelopeBuilderEx.CreateEnvelope(xMin, yMin, xMax, yMax, spatialReference);
        mapView.PanTo(envelope);
    Requirements
