public ViewAnimation Animation {get;}
Public ReadOnly Property Animation As ViewAnimation
//Return the collection representing the camera for each frame in animation.
await QueuedTask.Run(() =>
var animation = mapView.Map.Animation;
var cameras = new List<Camera>();
//We will use ticks here rather than milliseconds to get the highest precision possible.
var ticksPerFrame = Convert.ToInt64(animation.Duration.Ticks / (animation.NumberOfFrames - 1));
for (int i = 0; i < animation.NumberOfFrames; i++)
var time = TimeSpan.FromTicks(i * ticksPerFrame);
//Because of rounding for ticks the last calculated time may be greater than the duration.
if (time > animation.Duration)
time = animation.Duration;
cameras.Add(mapView.Animation.GetCameraAtTime(time));
// Use cameras
//Return the collection representing the map time for each frame in animation.
var timeRanges = new List<TimeRange>();
timeRanges.Add(mapView.Animation.GetCurrentTimeAtTime(time));
// Use timeRanges;
var ranges = new List<ArcGIS.Desktop.Mapping.Range>();
//Because of rounding for ticks the last calculated time may be greeting than the duration.
ranges.Add(mapView.Animation.GetCurrentRangeAtTime(time));
// Use ranges
