ArcGIS.Desktop.Mapping Namespace / ViewAnimation Class
Members
    ViewAnimation Class
    Allows control of the frame or time along an animation for the view.
    Object Model
    ViewAnimation ClassCamera ClassRange ClassTimeRange Class
    Syntax
    Public NotInheritable Class ViewAnimation
    public sealed class ViewAnimation
    Remarks
    Similar to how the map defines the layers that make up the map, the map defines the Animation and the collection of Keyframe objects for all views of the map. However, it is possible to have multiple views of a map set to different times or frames in the animation. An instance of this class is returned from the MapView.Animation property and can be used to set the current time or frame, step to the next or previous keyframe, or play and stop the animation.
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.ViewAnimation
    Requirements
