ArcGIS.Desktop.Mapping Namespace / MapView Class / CanSetMapTOCContent Method
The content type to check for
Example
    Gets whether the specified map TOC content type can be set on the active TOC.
    Syntax
    public bool CanSetMapTOCContent(
       MapTOCContentType mapTOCContentType
    Public Function CanSetMapTOCContent( _
       ByVal mapTOCContentType As MapTOCContentType _
    ) As Boolean
    Parameters
    mapTOCContentType
    Return Value
    Returns true if the requested content type is present in the TOC. Otherwise false.
    Remarks
    If the active TOC is not a map TOC, false will always be returned. Note: As link charts use a map TOC, CanSetMapTOCContent(...) can be used when a link chart is the active "map" view
    Example
    Set the Active Map TOC content type
      //Get the current active TOC content type for the map view
      var mapTOCContentType = (int)MapView.Active.CurrentMapTOCContent;
      //increment to the next tab whatever it is
      mapTOCContentType++;
      //Can we set this type on the TOC?
      if (MapView.Active.CanSetMapTOCContent((MapTOCContentType)mapTOCContentType))
        //Set it - must be on the UI! - No QueuedTask
        MapView.Active.SetMapTOCContentAsync((MapTOCContentType)mapTOCContentType);
      else
        mapTOCContentType = (int)MapTOCContentType.DrawingOrder;
    Requirements
    ArcGIS Pro version: 3.6 or higher.
