//Create a table frame.
await QueuedTask.Run(() =>
//Build 2D envelope geometry
Coordinate2D rec_ll = new Coordinate2D(1.0, 3.5);
Coordinate2D rec_ur = new Coordinate2D(7.5, 4.5);
Envelope rec_env = EnvelopeBuilderEx.CreateEnvelope(rec_ll, rec_ur);
//Reference map frame and layer
MapFrame mf = layout.FindElement("Map Frame") as MapFrame;
FeatureLayer lyr = mf.Map.FindLayers("GreatLakes").First() as FeatureLayer;
//Build fields list
var fields = new[] { "NAME", "Shape_Area", "Shape_Length" };
//Construct the table frame
var tableFrameInfo = new TableFrameInfo()
FieldNames = fields,
MapFrameName = mf.Name,
MapMemberUri = lyr.URI
var tabFrame = ElementFactory.Instance.CreateMapSurroundElement(
layout, rec_env, tableFrameInfo) as TableFrame;
var project = Project.Current;
//Get the Style project items in the project
var styleProjectItems = project?.GetItems<StyleProjectItem>();
//Get the ArcGIS 2D Style Project Item
var styleProjectItem =
styleProjectItems.OfType<StyleProjectItem>().FirstOrDefault(s => s.Name == "ArcGIS 2D");
if (styleProjectItem == null)
return;
//Get the grid style item you need
var gridStyleItem =
styleProjectItem.SearchSymbols(StyleItemType.Grid, "Blue Vertical Label Graticule").FirstOrDefault();
if (gridStyleItem == null)
return;
var symbolItemName = gridStyleItem.Name;
var girdGraticuleObject = gridStyleItem.GetObject() as CIMMapGrid;
var cmf = mapFrame.GetDefinition() as CIMMapFrame;
//note, if page units are _not_ inches then grid's gridline
//lengths and offsets would need to be converted to the page units
var mapGrids = new List<CIMMapGrid>();
if (cmf.Grids != null)
mapGrids.AddRange(cmf.Grids);
switch (girdGraticuleObject)
case CIMGraticule:
var gridGraticule = girdGraticuleObject as CIMGraticule;
gridGraticule.Name = symbolItemName;
gridGraticule.SetGeographicCoordinateSystem(mapFrame.Map.SpatialReference);
//assign grid to the frame
mapGrids.Add(gridGraticule);
break;
case CIMMeasuredGrid:
var gridMeasure = girdGraticuleObject as CIMMeasuredGrid;
gridMeasure.Name = symbolItemName;
gridMeasure.SetProjectedCoordinateSystem(mapFrame.Map.SpatialReference);
mapGrids.Add(gridMeasure);
break;
case CIMReferenceGrid:
var gridReference = girdGraticuleObject as CIMReferenceGrid;
gridReference.Name = symbolItemName;
mapGrids.Add(gridReference);
break;
cmf.Grids = mapGrids.ToArray();
mapFrame.SetDefinition(cmf);
//Zoom map frame to the extent of a single layer.
//Reference map and layer
Map m = mapFrame.Map;
FeatureLayer lyr = m.FindLayers("GreatLakes").First() as FeatureLayer;
//Set the map frame extent to all features in the layer
mapFrame.SetCamera(lyr, false);
//Change the extent of a map frame to the selected features multiple layers.
//Reference MapFrame
//Reference map, layers and create layer list
FeatureLayer fl_1 = m.FindLayers("GreatLakes").First() as FeatureLayer;
FeatureLayer fl_2 = m.FindLayers("States_WithRegions").First() as FeatureLayer;
var layers = new[] { fl_1, fl_2 };
//IEnumerable<Layer> layers = m.Layers; //This creates a list of ALL layers in map.
//Set the map frame extent to the selected features in the list of layers
mapFrame.SetCamera(layers, true);
//Change map frame extent to single feature with 10 percent buffer
//Reference the mapframe and its associated map
//Reference a feature layer and build a query (to return a single feature)
FeatureLayer fl = m.FindLayers("GreatLakes").First() as FeatureLayer;
QueryFilter qf = new QueryFilter();
string whereClause = "NAME = 'Lake Erie'";
qf.WhereClause = whereClause;
//Zoom to the feature
using (ArcGIS.Core.Data.RowCursor rowCursor = fl.Search(qf))
while (rowCursor.MoveNext())
//Get the shape from the row and set extent
using (var feature = rowCursor.Current as ArcGIS.Core.Data.Feature)
Polygon polygon = feature.GetShape() as Polygon;
Envelope env = polygon.Extent as Envelope;
mapFrame.SetCamera(env);
//Zoom out 15 percent
Camera cam = mapFrame.Camera;
cam.Scale = cam.Scale * 1.15;
mapFrame.SetCamera(cam);
var autoCamera = mapFrame.GetAutoCamera();
autoCamera.Source = AutoCameraSource.Fixed;
autoCamera.AutoCameraType = AutoCameraType.Extent;
var mf_extent = mapFrame.GetViewExtent();
var extent = EnvelopeBuilderEx.CreateEnvelope(
400748.62, 800296.4, 1310669.05, 1424520.74, mapFrame.Map.SpatialReference);
autoCamera.Extent = extent;
if (mapFrame.ValidateAutoCamera(autoCamera) &&
!mapFrame.IsMapSeriesMapFrame())
mapFrame.SetAutoCamera(autoCamera);
var activeLayoutView = LayoutView.Active;
autoCamera.AutoCameraType = AutoCameraType.Center;
var camera = mapFrame.GetMapView(activeLayoutView).Camera;
var center = mapFrame.GetViewCenter();
//var extent = EnvelopeBuilderEx.CreateEnvelope(
// 400748.62, 800296.4, 1310669.05, 1424520.74, mf.Map.SpatialReference);
//autoCamera.Extent = extent;
var camera2 = new CIMViewCamera()
Heading = 0,
Pitch = -90,
Roll = 0,
Scale = 21169571,
X = 855708,
Y = 1112409,
Z = double.NaN
autoCamera.Camera = camera2;
var states = mapFrame.Map.GetLayersAsFlattenedList().First(l => l.Name == "State_Polygons");
autoCamera.IntersectLayerPath = states.URI;
autoCamera.AutoCameraType = AutoCameraType.CenterAndScale;
Heading = 0,
Pitch = -90,
Roll = 0,
Scale = 21169571,
X = 1310669.0 + ((400748.5 - 1310669.0) / 2.0),
Y = 800296.4 + ((1424520.74 - 800296.4) / 2.0),
Z = double.NaN
//autoCamera.IntersectLayerPath = states.URI;
autoCamera.AutoCameraType = AutoCameraType.Scale;
Heading = 0,
Pitch = -90,
Roll = 0,
Scale = 20000571,
Z = double.NaN
autoCamera.Source = AutoCameraSource.MapFrameLink;
autoCamera.MapFrameLinkName = "mapFrameLink";
autoCamera.Source = AutoCameraSource.MapSeriesLink;
//autoCamera.MapFrameLinkName = mapFrameLink;
