ArcGIS.Desktop.Mapping Namespace / ISymbolFactory Interface / ConstructPolygonSymbol Method / ConstructPolygonSymbol(CIMColor,SimpleStipplePattern,CIMColor) Method
Example
    Constructs a polygon symbol of specific color, fill color, and stipple pattern.
    Syntax
    Overloads Function ConstructPolygonSymbol( _
       ByVal color As CIMColor, _
       ByVal stipplePattern As SimpleStipplePattern, _
       ByVal fillColor As CIMColor _
    ) As CIMPolygonSymbol
    Parameters
    color
    stipplePattern
    fillColor
    Return Value
    Remarks
    The polygon symbol outline and stipple color are specified with "color". The underlying fill color is specified via "fillColor". Fill color can be null to create a hollow background fill. Note: the stipple pattern is generated with a marker not a fill.
    Example
    Procedural Symbol
    /// <summary>
    /// Create a procedural symbol that can be applied to a polygon building footprint layer
    /// ![ProceduralSymbol](https://ArcGIS.github.io/arcgis-pro-sdk/images/Symbology/polygon-procedural.png)
    /// Note: The rule package used in this method can be obtained from the Sample Data included in the arcgis-pro-sdk-community-samples repository.
    /// </summary>
      //Note: Run withing QueuedTask
      string _rulePkgPath = @"C:\Data\RulePackages\Venice_2014.rpk";
      //Polygon symbol to hold the procedural layer
      var proceduralSymbol = SymbolFactory.Instance.ConstructPolygonSymbol();
      //Array of layers to hold a procedural symbol layer
      CIMSymbolLayer[] proceduralSymbolLyr =
                new CIMProceduralSymbolLayer()
                    PrimitiveName = "Venice Rule package 2014",
                    RulePackage = _rulePkgPath,
                    RulePackageName = "Venice_2014",
      proceduralSymbol.SymbolLayers = proceduralSymbolLyr;
      //To apply the symbol to a polygon feature layer
      //var renderer = theLayer.GetRenderer() as CIMSimpleRenderer;
      //renderer.Symbol = proceduralSymbol.MakeSymbolReference();
      //theLayer.SetRenderer(renderer);
    Requirements
    ArcGIS Pro version: 3.1 or higher.
