ArcGIS.Desktop.Mapping Namespace / IDisplayTable Interface / GetSelection Method
    GetSelection Method (IDisplayTable)
    Gets the current selection of a MapMember. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Selection GetSelection()
    Function GetSelection() As Selection
    Exceptions
    ExceptionDescription
    Remarks
    To ensure maximum robustness, callers should explicitly dispose of the returned ArcGIS.Core.Data.Selection in either a using statement or a finally block.
    Requirements
