ArcGIS.Desktop.Mapping Namespace / ILayerContainerEdit Interface / MoveLayer Method
A Layer to be moved.
The position specified by the 0-based index. If the index is invalid, the layer is moved to the bottom.
    MoveLayer Method (ILayerContainerEdit)
    Move a layer to another position within the container. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Sub MoveLayer( _
       ByVal layer As Layer, _
       ByVal position As Integer _
    void MoveLayer(
       Layer layer,
       int position
    Parameters
    layer
    position
    Exceptions
    ExceptionDescription
    Requirements
