Public Shared ReadOnly Property JobsManager As IJobsManager
public static IJobsManager JobsManager {get;}
// Get the job Id associated with the active map view
var jobManager = WorkflowClientModule.JobsManager;
jobId = jobManager.GetJobId();
// Use the jobId to identify the job associated with the active map view
// Get the job Id associated with a map
jobId = jobManager.GetJobId(mapUri);
// Use the jobId to identify the job associated with the map
// Note: QueuedTask is required to call Workflow Manager API methods
// GetJob returns an existing job
try
var job = jobManager.GetJob(jobId);
// Do something with the job
catch (NotConnectedException)
// Not connected to Workflow Manager server, do some error handling
catch (Exception)
// Some other exception occurred, do some error handling
// Use the job object
var search = new SearchQuery()
// Search for all open high priority jobs assigned to users
Q = "closed=0 AND assignedType='User' AND priority='High'",
Fields = ["jobId", "jobName", "assignedTo", "dueDate"],
// Sort by job assignment in ascending order and due date in descending order
SortFields =
new SortField() { FieldName = "assignedTo", SortOrder = SortOrder.Asc },
new SortField() { FieldName = "dueDate", SortOrder = SortOrder.Desc }
var searchResults = jobManager.SearchJobs(search);
var fields = searchResults.Fields;
var results = searchResults.Results;
// Search for jobs assigned to the current user using the arcade expression '$currentUser'
Q = "\"assignedType='User' AND closed=0 AND assignedTo='\" + $currentUser + \"' \"",
// Sort by job name in ascending order
SortFields = [new SortField() { FieldName = "jobName", SortOrder = SortOrder.Asc }]
var search = new SearchQuery() { Search = "My Search String" };
// Use the fields and results collections
var query = new JobStatisticsQuery()
// Search for open jobs assigned to users
Q = "\"assignedType='User' AND closed=0 \""
var results = jobManager.CalculateJobStatistics(query);
var totalJobs = results.Total;
jobManager.RunSteps(jobId);
// Specify specific current steps in a job to run
var stepIds = new List<string> { "step12345", "step67890" };
jobManager.RunSteps(jobId, stepIds);
// Stop the current steps in the job with the given id.
jobManager.StopSteps(jobId);
// Specify specific running steps in a job to stop
List<string> stepIds = ["step12345", "step67890"];
jobManager.StopSteps(jobId, stepIds);
// Finish the current steps in the job with the given id.
jobManager.FinishSteps(jobId);
jobManager.FinishSteps(jobId, stepIds);
