public CIMRasterColorizer GetColorizer()
Public Function GetColorizer() As CIMRasterColorizer
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
await QueuedTask.Run(() =>
// Get the colorizer from the raster layer.
CIMRasterColorizer rasterColorizer = rasterLayer.GetColorizer();
// Update raster colorizer properties.
rasterColorizer.Brightness = 10;
rasterColorizer.Contrast = -5;
rasterColorizer.ResamplingType = RasterResamplingType.NearestNeighbor;
// Update the raster layer with the changed colorizer.
rasterLayer.SetColorizer(rasterColorizer);
CIMRasterColorizer rColorizer = rasterLayer.GetColorizer();
// Check if the colorizer is an RGB colorizer.
if (rColorizer is CIMRasterRGBColorizer rasterRGBColorizer)
// Update RGB colorizer properties.
rasterRGBColorizer.StretchType = RasterStretchType.ESRI;
rasterLayer.SetColorizer(rasterRGBColorizer);
// Get the image sub-layer from the mosaic layer.
ImageMosaicSubLayer mosaicImageSubLayer = mosaicLayer.GetImageLayer();
// Get the colorizer from the image sub-layer.
CIMRasterColorizer rasterColorizer = mosaicImageSubLayer.GetColorizer();
// Update the image sub-layer with the changed colorizer.
mosaicImageSubLayer.SetColorizer(rasterColorizer);
CIMRasterColorizer rColorizer = mosaicImageSubLayer.GetColorizer();
mosaicImageSubLayer.SetColorizer(rasterRGBColorizer);
// Get the colorizer from the image service layer.
CIMRasterColorizer rasterColorizer = imageServiceLayer.GetColorizer();
// Update the colorizer properties.
// Update the image service layer with the changed colorizer.
imageServiceLayer.SetColorizer(rasterColorizer);
CIMRasterColorizer rColorizer = imageServiceLayer.GetColorizer();
imageServiceLayer.SetColorizer((CIMRasterColorizer)rasterRGBColorizer);
//If a raster dataset has statistics, you can create a raster layer and get these statistics by accessing the colorizer. var rasterStatisticsMapView = MapView.Active; if (rasterStatisticsMapView == null) return; await QueuedTask.Run(() => { //Accessing the raster layer var lyr = rasterStatisticsMapView.Map.GetLayersAsFlattenedList().OfType<BasicRasterLayer>().FirstOrDefault(); //Getting the colorizer var colorizer = lyr.GetColorizer() as CIMRasterStretchColorizer; //Accessing the statistics var stats = colorizer.StretchStats; var max = stats.max; var min = stats.min; });
