ArcGIS.Desktop.Mapping Namespace / BasicRasterLayer Class / SetColorizer Method
Your custom colorizer that will be used to draw the raster layer.
Example
    SetColorizer Method
    Sets the colorizer. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetColorizer(
       CIMRasterColorizer colorizer
    Public Sub SetColorizer( _
       ByVal colorizer As CIMRasterColorizer _
    Parameters
    colorizer
    Exceptions
    ExceptionDescription
    Cannot set colorizer for layer.
    Remarks
    Use CanSetColorizer to determine if the colorizer is valid for the layer before updating it.
    Example
    Update the raster colorizer on a raster layer
      await QueuedTask.Run(() =>
        // Get the colorizer from the raster layer.
        CIMRasterColorizer rasterColorizer = rasterLayer.GetColorizer();
        // Update raster colorizer properties.
        rasterColorizer.Brightness = 10;
        rasterColorizer.Contrast = -5;
        rasterColorizer.ResamplingType = RasterResamplingType.NearestNeighbor;
        // Update the raster layer with the changed colorizer.
        rasterLayer.SetColorizer(rasterColorizer);
    Update the RGB colorizer on a raster layer
        CIMRasterColorizer rColorizer = rasterLayer.GetColorizer();
        // Check if the colorizer is an RGB colorizer.
        if (rColorizer is CIMRasterRGBColorizer rasterRGBColorizer)
          // Update RGB colorizer properties.
          rasterRGBColorizer.StretchType = RasterStretchType.ESRI;
          rasterLayer.SetColorizer(rasterRGBColorizer);
    Create a new colorizer based on a default colorizer definition and apply it to the raster layer
      await QueuedTask.Run(async () =>
        // Check if the Stretch colorizer can be applied to the raster layer.
        if (rasterLayer.GetApplicableColorizers().Contains(RasterColorizerType.StretchColorizer))
          // Create a new Stretch Colorizer Definition using the default constructor.
          StretchColorizerDefinition stretchColorizerDef_default = new StretchColorizerDefinition();
          // Create a new Stretch colorizer using the colorizer definition created above.
          CIMRasterStretchColorizer newStretchColorizer_default =
            await rasterLayer.CreateColorizerAsync(stretchColorizerDef_default) as CIMRasterStretchColorizer;
          // Set the new colorizer on the raster layer.
          rasterLayer.SetColorizer(newStretchColorizer_default);
    Create a new colorizer based on a custom colorizer definition and apply it to the raster layer
      //Get a color ramp from a style
      var project = Project.Current;
      StyleProjectItem ArcGISColorsStyleItem =
            project.GetItems<StyleProjectItem>().FirstOrDefault(s => s.Name == "ArcGIS Colors");
        var colorRamps = ArcGISColorsStyleItem.SearchColorRamps("Heat Map 4 - Semitransparent");
        CIMColorRamp colorRampToUse = colorRampList[0].ColorRamp;
          // Create a new Stretch Colorizer Definition specifying parameters
          // for band index, stretch type, gamma and color ramp.
          StretchColorizerDefinition stretchColorizerDef_custom =
            new StretchColorizerDefinition(1, RasterStretchType.ESRI, 2, colorRamp);
          // Create a new stretch colorizer using the colorizer definition created above.
          CIMRasterStretchColorizer newStretchColorizer_custom =
            await rasterLayer.CreateColorizerAsync(stretchColorizerDef_custom) as CIMRasterStretchColorizer;
          rasterLayer.SetColorizer(newStretchColorizer_custom);
    Update the raster colorizer on a mosaic layer
      // Get the image sub-layer from the mosaic layer.
      ImageMosaicSubLayer mosaicImageSubLayer = mosaicLayer.GetImageLayer();
      // Get the colorizer from the image sub-layer.
      CIMRasterColorizer rasterColorizer = mosaicImageSubLayer.GetColorizer();
      // Update the image sub-layer with the changed colorizer.
      mosaicImageSubLayer.SetColorizer(rasterColorizer);
    Update the RGB colorizer on a mosaic layer
      CIMRasterColorizer rColorizer = mosaicImageSubLayer.GetColorizer();
        mosaicImageSubLayer.SetColorizer(rasterRGBColorizer);
    Create a new colorizer based on a default colorizer definition and apply it to the mosaic layer
        // Check if the Stretch colorizer can be applied to the image sub-layer.
        if (mosaicImageSubLayer.GetApplicableColorizers().Contains(RasterColorizerType.StretchColorizer))
            await mosaicImageSubLayer.CreateColorizerAsync(stretchColorizerDef_default) as CIMRasterStretchColorizer;
          // Set the new colorizer on the image sub-layer.
          mosaicImageSubLayer.SetColorizer(newStretchColorizer_default);
    Create a new colorizer based on a custom colorizer definition and apply it to the mosaic layer
          // Create a new Stretch colorizer definition specifying parameters
            await mosaicImageSubLayer.CreateColorizerAsync(stretchColorizerDef_custom) as CIMRasterStretchColorizer;
          mosaicImageSubLayer.SetColorizer(newStretchColorizer_custom);
    Update the raster colorizer on an image service layer
      // Get the colorizer from the image service layer.
      CIMRasterColorizer rasterColorizer = imageServiceLayer.GetColorizer();
      // Update the colorizer properties.
      // Update the image service layer with the changed colorizer.
      imageServiceLayer.SetColorizer(rasterColorizer);
    Update the RGB colorizer on an image service layer
      CIMRasterColorizer rColorizer = imageServiceLayer.GetColorizer();
        imageServiceLayer.SetColorizer((CIMRasterColorizer)rasterRGBColorizer);
    Create a new colorizer based on a default colorizer definition and apply it to the image service layer
        // Check if the Stretch colorizer can be applied to the image service layer.
        if (imageServiceLayer.GetApplicableColorizers().Contains(RasterColorizerType.StretchColorizer))
            await imageServiceLayer.CreateColorizerAsync(stretchColorizerDef_default) as CIMRasterStretchColorizer;
          // Set the new colorizer on the image service layer.
          imageServiceLayer.SetColorizer(newStretchColorizer_default);
    Create a new colorizer based on a custom colorizer definition and apply it to the image service layer
            await imageServiceLayer.CreateColorizerAsync(stretchColorizerDef_custom) as CIMRasterStretchColorizer;
          imageServiceLayer.SetColorizer(newStretchColorizer_custom);
    Requirements
