ArcGIS.Desktop.Mapping Namespace / BMPFormat Class / HasWorldFile Property
Example
    HasWorldFile Property (BMPFormat)
    Gets or sets if a georeferenced world file will be created.
    Syntax
    public bool HasWorldFile {get; set;}
    Public Property HasWorldFile As Boolean
    Remarks
    If set to true, the file will contain pixel scale and real-world coordinate information. World files are not generated for Layout exports.
    If you export a 3D view, this parameter will be ignored regardless of the setting because world files are not applicable to 3D views.
    The default value is false.
    Example
    Export the map view associated with a map frame to BMP
      //Export the map view associated with a map frame to BMP.
      string filePath = @"Path and file name for the output export file";
      //Create BMP format with appropriate settings
      //EMF, EPS, GIF, JPEG, PDF, PNG, SVG, TGA, and TFF formats are also available for export
      BMPFormat BMP = new BMPFormat()
        Resolution = 300,
        Height = 500,
        Width = 800,
        HasWorldFile = true,
        OutputFileName = filePath
      //Export on the worker thread
      await QueuedTask.Run(() =>
        MapView mv_bmp = mapFrame.GetMapView(layoutView);
        if (mv_bmp != null)
          //Check to see if the path is valid and export
          if (BMP.ValidateOutputFilePath())
            mv_bmp.Export(BMP);  //Export to BMP
    Requirements
