public class BMPFormat : ExportFormat
Public Class BMPFormat Inherits ExportFormat
//Export the map view associated with a map frame to BMP.
string filePath = @"Path and file name for the output export file";
//Create BMP format with appropriate settings
//EMF, EPS, GIF, JPEG, PDF, PNG, SVG, TGA, and TFF formats are also available for export
BMPFormat BMP = new BMPFormat()
Resolution = 300,
Height = 500,
Width = 800,
HasWorldFile = true,
OutputFileName = filePath
//Export on the worker thread
await QueuedTask.Run(() =>
MapView mv_bmp = mapFrame.GetMapView(layoutView);
if (mv_bmp != null)
//Check to see if the path is valid and export
if (BMP.ValidateOutputFilePath())
mv_bmp.Export(BMP); //Export to BMP
System.Object
ArcGIS.Desktop.Mapping.ExportFormat
ArcGIS.Desktop.Mapping.BMPFormat
