ArcGIS.Desktop.Mapping Namespace / Bookmark Class / Rename Method
The new bookmark name.
Example
    Rename Method (Bookmark)
    Changes the name of the bookmark. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void Rename(
       string name
    Public Sub Rename( _
       ByVal name As String _
    Parameters
    name
    Exceptions
    ExceptionDescription
    Example
    Rename Bookmark
      oldBookmark = mapView.Map.GetBookmarks().FirstOrDefault(b => b.Name == bookmarkName);
      oldBookmark.Rename(newBookmarkName);
    Requirements
