ArcGIS.Desktop.Mapping Namespace / Bookmark Class / SetDefinition Method
The definition used to update the bookmark.
Example
    SetDefinition Method (Bookmark)
    Updates the bookmark using a CIM definition of a bookmark. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetDefinition(
       CIMBookmark bookmark
    Public Sub SetDefinition( _
       ByVal bookmark As CIMBookmark _
    Parameters
    bookmark
    Exceptions
    ExceptionDescription
    Example
    Update Extent for a Bookmark
      await QueuedTask.Run(() =>
        //Get the bookmark's definition
        var bookmarkDef = oldBookmark.GetDefinition();
        //Modify the bookmark's location
        bookmarkDef.Location = envelope;
        //Clear the camera as it is no longer valid.
        bookmarkDef.Camera = null;
        //Set the bookmark definition
        oldBookmark.SetDefinition(bookmarkDef);
    Requirements
