ArcGIS.Desktop.Workflow.Client.Models Namespace / IJobsManager Interface / GetJobId Method / GetJobId() Method
Example
    GetJobId() Method
    Gets the job Id associated with the active map view. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Overloads Function GetJobId() As String
    string GetJobId()
    Example
    return await QueuedTask.Run(() => { return WorkflowClientModule.JobsManager.GetJobId(); });
    Get the job Id associated with the active map view
      // Get the job Id associated with the active map view
      var jobManager = WorkflowClientModule.JobsManager;
      jobId = jobManager.GetJobId();
      // Use the jobId to identify the job associated with the active map view
    Requirements
    ArcGIS Pro version: 3.1 or higher.
