ArcGIS.Desktop.Workflow.Client.Models Namespace / IJobsManager Interface / GetJobId Method / GetJobId(String) Method
The map uri of the map
Example
    Gets the job Id associated with the map. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Overloads Function GetJobId( _
       ByVal mapUri As String _
    ) As String
    string GetJobId(
       string mapUri
    Parameters
    mapUri
    Example
    return await QueuedTask.Run(() => { Map map = MapView.Active.Map; // Get a reference to a map using the Mapping API (active view, project item, etc.) return WorkflowClientModule.JobsManager.GetJobId(map.Uri); });
    Get the job Id associated with the active map view
      // Get the job Id associated with the active map view
      var jobManager = WorkflowClientModule.JobsManager;
      jobId = jobManager.GetJobId();
      // Use the jobId to identify the job associated with the active map view
    Get the job Id associated with a map
      // Get the job Id associated with a map
      jobId = jobManager.GetJobId(mapUri);
      // Use the jobId to identify the job associated with the map
    Requirements
    ArcGIS Pro version: 3.1 or higher.
