string colorBrewerSchemesName = "ColorBrewer Schemes (RGB)";
StyleProjectItem colorBrewerStyle = Project.Current.GetItems<StyleProjectItem>().First(s => s.Name == colorBrewerSchemesName);
string colorRampName = "Greens (Continuous)";
IList<ColorRampStyleItem> colorRampListFromTheStyle = await QueuedTask.Run(() =>
colorBrewerStyle.SearchColorRamps(colorRampName));
ColorRampStyleItem colorRampFound = colorRampList[0];
GraduatedColorsRendererDefinition gcDef = new GraduatedColorsRendererDefinition()
ClassificationField = "CROP_ACR07",
ClassificationMethod = ArcGIS.Core.CIM.ClassificationMethod.NaturalBreaks,
BreakCount = 6,
ColorRamp = colorRampFound.ColorRamp,
SymbolTemplate = SymbolFactory.Instance.ConstructPolygonSymbol(
ColorFactory.Instance.GreenRGB, SimpleFillStyle.Solid, null).MakeSymbolReference(),
ExclusionClause = "CROP_ACR07 = -99",
ExclusionSymbol = SymbolFactory.Instance.ConstructPolygonSymbol(
ColorFactory.Instance.RedRGB, SimpleFillStyle.Solid, null).MakeSymbolReference(),
ExclusionLabel = "No yield",
var featureLayerCreationParams = new FeatureLayerCreationParams((new Uri(@"c:\Data\CountyData.gdb\Counties")))
Name = "Crop",
RendererDefinition = gcDef
LayerFactory.Instance.CreateLayer<FeatureLayer>(featureLayerCreationParams, map));
/// <summary> /// Renders a feature layer using graduated colors to draw quantities. ///  /// </summary> { //Check feature layer name //Code works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data var featureLayer = activeMap.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(f => f.Name == "USDemographics"); if (featureLayer == null) { MessageBox.Show("This renderer works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data", "Data missing"); } GraduatedColorsRendererDefinition gcDef = new GraduatedColorsRendererDefinition() { ClassificationField = "NumericFieldInFeatureLayer", ClassificationMethod = ClassificationMethod.NaturalBreaks, BreakCount = 5, ColorRamp = colorRamp, }; await QueuedTask.Run(() => { CIMClassBreaksRenderer renderer = (CIMClassBreaksRenderer)featureLayer.CreateRenderer(gcDef); featureLayer?.SetRenderer(renderer); }); }
/// <summary> /// Renders a feature layer using graduated colors to draw quantities. The outline width is varied based on attributes. ///  /// </summary> { //Check feature layer name //Code works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data var featureLayer = activeMap.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(f => f.Name == "USDemographics"); if (featureLayer == null) { MessageBox.Show("This renderer works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data", "Data missing"); } //Gets the first numeric field of the feature layer var firstNumericFieldOfFeatureLayer = "NumericFieldInFeatureLayer"; //Gets the min and max value of the field var minMax = await GetFieldMinMaxAsync(featureLayer, firstNumericFieldOfFeatureLayer); GraduatedColorsRendererDefinition gcDef = new GraduatedColorsRendererDefinition() { ClassificationField = "NumericFieldInFeatureLayer", ClassificationMethod = ClassificationMethod.NaturalBreaks, BreakCount = 5, ColorRamp = colorRamp }; CIMClassBreaksRenderer renderer = await QueuedTask.Run(() => (CIMClassBreaksRenderer)featureLayer.CreateRenderer(gcDef)); //Create array of CIMVisualVariables to hold the outline information. var visualVariables = new CIMVisualVariable[] { new CIMSizeVisualVariable { ValueExpressionInfo = new CIMExpressionInfo { Title = "Custom", Expression = "$feature.AREA", ReturnType = ExpressionReturnType.Default }, AuthoringInfo = new CIMVisualVariableAuthoringInfo { MinSliderValue = Convert.ToDouble(minMax.Item1), MaxSliderValue = Convert.ToDouble(minMax.Item2), ShowLegend = false, Heading = firstNumericFieldOfFeatureLayer }, VariableType = SizeVisualVariableType.Graduated, Target = "outline", MinSize = 1, MaxSize = 13, MinValue = Convert.ToDouble(minMax.Item1), MaxValue = Convert.ToDouble(minMax.Item2) }, }; renderer.VisualVariables = visualVariables; await QueuedTask.Run(() => featureLayer?.SetRenderer(renderer)); }
/// <summary> /// Renders a feature layer using graduated symbols and natural breaks to draw quantities. ///  /// </summary> { //Check feature layer name //Code works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data var featureLayer = activeMap.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(f => f.Name == "USDemographics"); if (featureLayer == null) { MessageBox.Show("This renderer works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data", "Data missing"); } GraduatedSymbolsRendererDefinition gsDef = new GraduatedSymbolsRendererDefinition() { ClassificationField = "NumericFieldInFeatureLayer", //getting the first numeric field ClassificationMethod = ClassificationMethod.NaturalBreaks, SymbolTemplate = SymbolFactory.Instance.ConstructPointSymbol(CIMColor.CreateRGBColor(76, 230, 0)).MakeSymbolReference(), MinimumSymbolSize = 4, MaximumSymbolSize = 50, BreakCount = 5, ColorRamp = colorRamp, //getting a color ramp }; await QueuedTask.Run(() => { CIMClassBreaksRenderer renderer = (CIMClassBreaksRenderer)featureLayer.CreateRenderer(gsDef); featureLayer?.SetRenderer(renderer); }); }
