ArcGIS.Desktop.Mapping Namespace / ClassBreaksRendererDefinition Class
Properties
    ClassBreaksRendererDefinition Class Members
    The following tables list the members exposed by ClassBreaksRendererDefinition.
    Public Properties
     NameDescription
    Public PropertyGets or sets the arcade expression used in the renderer. This is required if ClassificationField is null.
    Public Property Gets or sets number of desired class breaks. The default value is 5.
    Public PropertyGets or sets field name used in the renderer. This is required if ArcadeExpression is null.
    Public PropertyGets and sets classification method to be used to compute class breaks. This is required. The default value is ArcGIS.Core.CIM.ClassificationMethod.NaturalBreaks.
    Public Property Gets or sets the color ramp be used to pick color for symbols from.
    Public Property Gets or set standard deviation interval.
    Public Property Gets or sets a SQL statement to exclude features while computing class breaks.
    Public Property Gets or sets the label used on the TOC for exclusion symbol.
    Public PropertyGets or sets symbol to be used to draw features that are excluded since they meet ExclusionClause criteria.
    Public Property Gets or sets the interval size.
    Public PropertyGets or sets the field which will be used to normalize data when 'Field' is selected as the DataNormalizationMethod.
    Public Property Gets or sets the method be used to normalized data.
    Public Property Gets or sets the number format used in the renderer.
    Public Property Gets or sets the out of range description used in the renderer.
    Public Property Gets or sets the out of range label used in the renderer.
    Public Property Gets or sets the out of range symbol used in the renderer.
    Public Property Gets or sets number of records be used as samples to compute class breaks.
    Public Property Gets or sets a template for symbol used in the renderer.
    Public Property Gets or sets a boolean to indicate that OutOfRangeSymbol will be used to draw features whose values are not found in the values list.
    Top
