ArcGIS.Desktop.Mapping Namespace / ClassBreaksRendererDefinition Class / ClassificationField Property
Example
    ClassificationField Property (ClassBreaksRendererDefinition)
    Gets or sets field name used in the renderer. This is required if ArcadeExpression is null.
    Syntax
    Public Property ClassificationField As String
    public string ClassificationField {get; set;}
    Example
    Create a feature layer with class breaks renderer
        string colorBrewerSchemesName = "ColorBrewer Schemes (RGB)";
        StyleProjectItem colorBrewerStyle = Project.Current.GetItems<StyleProjectItem>().First(s => s.Name == colorBrewerSchemesName);
        string colorRampName = "Greens (Continuous)";
        //Note: Needs QueuedTask to run
        IList<ColorRampStyleItem> colorRampListFromTheStyle = colorBrewerStyle.SearchColorRamps(colorRampName);
        ColorRampStyleItem colorRampFound = colorRampList[0];
        GraduatedColorsRendererDefinition gcDef = new GraduatedColorsRendererDefinition()
            ClassificationField = "CROP_ACR07",
            ClassificationMethod = ArcGIS.Core.CIM.ClassificationMethod.NaturalBreaks,
            BreakCount = 6,
            ColorRamp = colorRampFound.ColorRamp,
            SymbolTemplate = SymbolFactory.Instance.ConstructPolygonSymbol(
                                  ColorFactory.Instance.GreenRGB, SimpleFillStyle.Solid, null).MakeSymbolReference(),
            ExclusionClause = "CROP_ACR07 = -99",
            ExclusionSymbol = SymbolFactory.Instance.ConstructPolygonSymbol(
                                  ColorFactory.Instance.RedRGB, SimpleFillStyle.Solid, null).MakeSymbolReference(),
            ExclusionLabel = "No yield",
        var featureLayerCreationParams = new FeatureLayerCreationParams((new Uri(@"c:\Data\CountyData.gdb\Counties")))
            Name = "Crop",
            RendererDefinition = gcDef
        LayerFactory.Instance.CreateLayer<FeatureLayer>(featureLayerCreationParams, MapView.Active.Map);
    Requirements
