ArcGIS.Desktop.Mapping Namespace / ClassBreaksRendererDefinition Class / SymbolTemplate Property
Example
    SymbolTemplate Property (ClassBreaksRendererDefinition)
    Gets or sets a template for symbol used in the renderer.
    Syntax
    public CIMSymbolReference SymbolTemplate {get; set;}
    Public Property SymbolTemplate As CIMSymbolReference
    Example
    Create a feature layer with class breaks renderer
      string colorBrewerSchemesName = "ColorBrewer Schemes (RGB)";
      StyleProjectItem colorBrewerStyle = Project.Current.GetItems<StyleProjectItem>().First(s => s.Name == colorBrewerSchemesName);
      string colorRampName = "Greens (Continuous)";
      IList<ColorRampStyleItem> colorRampListFromTheStyle = await QueuedTask.Run(() =>
        colorBrewerStyle.SearchColorRamps(colorRampName));
      ColorRampStyleItem colorRampFound = colorRampList[0];
      GraduatedColorsRendererDefinition gcDef = new GraduatedColorsRendererDefinition()
        ClassificationField = "CROP_ACR07",
        ClassificationMethod = ArcGIS.Core.CIM.ClassificationMethod.NaturalBreaks,
        BreakCount = 6,
        ColorRamp = colorRampFound.ColorRamp,
        SymbolTemplate = SymbolFactory.Instance.ConstructPolygonSymbol(
                                ColorFactory.Instance.GreenRGB, SimpleFillStyle.Solid, null).MakeSymbolReference(),
        ExclusionClause = "CROP_ACR07 = -99",
        ExclusionSymbol = SymbolFactory.Instance.ConstructPolygonSymbol(
                                ColorFactory.Instance.RedRGB, SimpleFillStyle.Solid, null).MakeSymbolReference(),
        ExclusionLabel = "No yield",
      var featureLayerCreationParams = new FeatureLayerCreationParams((new Uri(@"c:\Data\CountyData.gdb\Counties")))
        Name = "Crop",
        RendererDefinition = gcDef
        LayerFactory.Instance.CreateLayer<FeatureLayer>(featureLayerCreationParams, map));
    Class Breaks renderer with graduated symbols.
    /// <summary>
    /// Renders a feature layer using graduated symbols and natural breaks to draw quantities.
    /// ![cb-symbols.png](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/cb-symbols.png "Graduated symbols with natural breaks renderer.")
    /// </summary>
      //Check feature layer name
      //Code works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data
      var featureLayer = activeMap.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(f => f.Name == "USDemographics");
      if (featureLayer == null)
        MessageBox.Show("This renderer works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data", "Data missing");
      GraduatedSymbolsRendererDefinition gsDef = new GraduatedSymbolsRendererDefinition()
        ClassificationField = "NumericFieldInFeatureLayer", //getting the first numeric field
        ClassificationMethod = ClassificationMethod.NaturalBreaks,
        SymbolTemplate = SymbolFactory.Instance.ConstructPointSymbol(CIMColor.CreateRGBColor(76, 230, 0)).MakeSymbolReference(),
        MinimumSymbolSize = 4,
        MaximumSymbolSize = 50,
        BreakCount = 5,
        ColorRamp = colorRamp, //getting a color ramp
        CIMClassBreaksRenderer renderer = (CIMClassBreaksRenderer)featureLayer.CreateRenderer(gsDef);
        featureLayer?.SetRenderer(renderer);
    Requirements
