ArcGIS.Desktop.Mapping Namespace / ColorFactory Class / GreyRGB Property
Example
    GreyRGB Property (ColorFactory)
    Gets the grey color.
    Syntax
    Public ReadOnly Property GreyRGB As CIMColor
    public CIMColor GreyRGB {get;}
    Example
    Create Ellipse Graphic Element
      //Note: Must be on QueuedTask.Run
      //Build geometry
      Coordinate2D center = new Coordinate2D(2, 2.75);
      var eabElp = new EllipticArcBuilderEx(center, 0, 1, 0.45,
                                          ArcOrientation.ArcClockwise);
      var ellipse = eabElp.ToSegment();
      //Set symbology, create and add element to layout
      CIMStroke outline = SymbolFactory.Instance.ConstructStroke(
                                      ColorFactory.Instance.GreenRGB, 2.0,
                              SimpleLineStyle.Dot);
      CIMPolygonSymbol ellipseSym = SymbolFactory.Instance.ConstructPolygonSymbol(
                                ColorFactory.Instance.GreyRGB, SimpleFillStyle.Vertical,
                                                        outline);
      var poly = PolygonBuilderEx.CreatePolygon(
        PolylineBuilderEx.CreatePolyline(ellipse, AttributeFlags.AllAttributes));
      var elpElm = ElementFactory.Instance.CreateGraphicElement(
        layout, poly, ellipseSym, "New Ellipse");
    Requirements
