Public Class ColorRampStyleItem Inherits StyleItem Implements System.ComponentModel.INotifyPropertyChanged
public class ColorRampStyleItem : StyleItem, System.ComponentModel.INotifyPropertyChanged
//StyleProjectItem can be "ColorBrewer Schemes (RGB)", "ArcGIS 2D"...
//Search for color ramps
//Color Ramp searchString can be "Spectral (7 Classes)", "Pastel 1 (3 Classes)", "Red-Gray (10 Classes)"..
styleProjectItem.SearchColorRamps("searchString");
string colorBrewerSchemesName = "ColorBrewer Schemes (RGB)";
StyleProjectItem colorBrewerStyle = Project.Current.GetItems<StyleProjectItem>().First(s => s.Name == colorBrewerSchemesName);
string colorRampName = "Greens (Continuous)";
//Note: Needs QueuedTask to run
IList<ColorRampStyleItem> colorRampListFromTheStyle = colorBrewerStyle.SearchColorRamps(colorRampName);
ColorRampStyleItem colorRampFound = colorRampList[0];
GraduatedColorsRendererDefinition gcDef = new GraduatedColorsRendererDefinition()
ClassificationField = "CROP_ACR07",
ClassificationMethod = ArcGIS.Core.CIM.ClassificationMethod.NaturalBreaks,
BreakCount = 6,
ColorRamp = colorRampFound.ColorRamp,
SymbolTemplate = SymbolFactory.Instance.ConstructPolygonSymbol(
ColorFactory.Instance.GreenRGB, SimpleFillStyle.Solid, null).MakeSymbolReference(),
ExclusionClause = "CROP_ACR07 = -99",
ExclusionSymbol = SymbolFactory.Instance.ConstructPolygonSymbol(
ColorFactory.Instance.RedRGB, SimpleFillStyle.Solid, null).MakeSymbolReference(),
ExclusionLabel = "No yield",
var featureLayerCreationParams = new FeatureLayerCreationParams((new Uri(@"c:\Data\CountyData.gdb\Counties")))
Name = "Crop",
RendererDefinition = gcDef
LayerFactory.Instance.CreateLayer<FeatureLayer>(featureLayerCreationParams, MapView.Active.Map);
// Note: call within QueuedTask.Run()
var fields = pointCloudSceneLayer.GetAvailablePointCloudRendererFields(
PointCloudRendererType.StretchRenderer);
var stretchDef = new PointCloudRendererDefinition(
//Will be either ELEVATION or INTENSITY
Field = fields[0]
//Create the CIM Renderer
var stretchRenderer = pointCloudSceneLayer.CreateRenderer(stretchDef)
as CIMPointCloudStretchRenderer;
//Apply a color ramp
var style = Project.Current.GetItems<StyleProjectItem>()
.First(s => s.Name == "ArcGIS Colors");
var colorRamp = style.SearchColorRamps("").First();
stretchRenderer.ColorRamp = colorRamp.ColorRamp;
//Apply modulation
stretchRenderer.ColorModulation = new CIMColorModulationInfo()
MinValue = 0,
MaxValue = 100
//apply the renderer
pointCloudSceneLayer.SetRenderer(stretchRenderer);
PointCloudRendererType.ClassBreaksRenderer);
var classBreakDef = new PointCloudRendererDefinition(
//ELEVATION or INTENSITY
Field = fields[0]
//create the renderer
var cbr = pointCloudSceneLayer.CreateRenderer(classBreakDef)
as CIMPointCloudClassBreaksRenderer;
//Set up a color scheme to use
var rampStyle = style.LookupItem(
StyleItemType.ColorRamp, "Spectrum By Wavelength-Full Bright_Multi-hue_2")
as ColorRampStyleItem;
var colorScheme = rampStyle.ColorRamp;
//Set up 6 manual class breaks
var breaks = 6;
var colors = ColorFactory.Instance.GenerateColorsFromColorRamp(
colorScheme, breaks);
var classBreaks = new List<CIMColorClassBreak>();
var min = cbr.Breaks[0].UpperBound;
var max = cbr.Breaks[cbr.Breaks.Count() - 1].UpperBound;
var step = (max - min) / (double)breaks;
//add in the class breaks
double upper = min;
for (int b = 1; b <= breaks; b++)
double lower = upper;
upper = b == breaks ? max : min + (b * step);
var cb = new CIMColorClassBreak()
UpperBound = upper,
Label = string.Format("{0:#0.0#} - {1:#0.0#}", lower, upper),
Color = colors[b - 1]
classBreaks.Add(cb);
cbr.Breaks = classBreaks.ToArray();
pointCloudSceneLayer.SetRenderer(cbr);
System.Object
ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
ArcGIS.Desktop.Mapping.StyleItem
ArcGIS.Desktop.Mapping.ColorRampStyleItem
