ArcGIS.Desktop.Mapping Namespace / ExportFormat Class / Width Property
Example
    Width Property (ExportFormat)
    Gets or sets the number of pixels that represents the width of the output file.
    Syntax
    public double Width {get; set;}
    Public Property Width As Double
    Remarks
    This property only applies to exporting map views. The value is ignored when exporting layouts or map frames.
    The default value is 960.
    Example
    Export a map frame to JPG
      //Export a map frame to JPG.
      string filePath = @"Path and file name for the output export file";
      //Create JPEG format with appropriate settings
      //BMP, EMF, EPS, GIF, PDF, PNG, SVG, TGA, and TFF formats are also available for export
      JPEGFormat JPG = new JPEGFormat()
        HasWorldFile = true,
        Resolution = 300,
        OutputFileName = filePath,
        ColorMode = JPEGColorMode.TwentyFourBitTrueColor,
        Height = 800,
        Width = 1200
      //Export on the worker thread
      await QueuedTask.Run(() =>
        //Reference the map frame
        MapFrame mf = layout.FindElement("MyMapFrame") as MapFrame;
        //Check to see if the path is valid and export
        if (JPG.ValidateOutputFilePath())
          mf.Export(JPG);  //Export the map frame to JPG
    Export the map view associated with a map frame to BMP
      //Export the map view associated with a map frame to BMP.
      //Create BMP format with appropriate settings
      //EMF, EPS, GIF, JPEG, PDF, PNG, SVG, TGA, and TFF formats are also available for export
      BMPFormat BMP = new BMPFormat()
        Resolution = 300,
        Height = 500,
        Width = 800,
        MapView mv_bmp = mapFrame.GetMapView(layoutView);
        if (mv_bmp != null)
          if (BMP.ValidateOutputFilePath())
            mv_bmp.Export(BMP);  //Export to BMP
    Requirements
