ArcGIS.Desktop.Mapping Namespace / GraduatedColorsRendererDefinition Class
Members Example
    Represents graduated color renderer definition to show qualitative differences in feature values with a range of color.
    Object Model
    GraduatedColorsRendererDefinition ClassCIMColorRamp ClassCIMSymbolReference ClassCIMNumberFormat ClassCIMSymbolReference ClassCIMSymbolReference Class
    Syntax
    Public Class GraduatedColorsRendererDefinition
       Inherits ClassBreaksRendererDefinition
    public class GraduatedColorsRendererDefinition : ClassBreaksRendererDefinition
    Remarks
    GraduatedColorsRendererDefinition class allow you to define parameters to create renderers to draw features with graduated color based on the values of a quantitative attribute that is statistically grouped by a classification algorithm.
    Once you define a graduated color renderer, you can call a FeatureLayer's CreateRenderer and SetRenderer methods to create and assign a renderer to a feature layer.
    Example
    Create a feature layer with class breaks renderer with defaults
        var featureLayerCreationParams = new FeatureLayerCreationParams(new Uri(@"c:\data\countydata.gdb\counties"))
            Name = "Population Density (sq mi) Year 2010",
            RendererDefinition = new GraduatedColorsRendererDefinition("POP10_SQMI")
        LayerFactory.Instance.CreateLayer<FeatureLayer>(
          featureLayerCreationParams,
          MapView.Active.Map
        string colorBrewerSchemesName = "ColorBrewer Schemes (RGB)";
        StyleProjectItem colorBrewerStyle = Project.Current.GetItems<StyleProjectItem>().First(s => s.Name == colorBrewerSchemesName);
        string colorRampName = "Greens (Continuous)";
        //Note: Needs QueuedTask to run
        IList<ColorRampStyleItem> colorRampListFromTheStyle = colorBrewerStyle.SearchColorRamps(colorRampName);
        ColorRampStyleItem colorRampFound = colorRampList[0];
        GraduatedColorsRendererDefinition gcDef = new GraduatedColorsRendererDefinition()
            ClassificationField = "CROP_ACR07",
            ClassificationMethod = ArcGIS.Core.CIM.ClassificationMethod.NaturalBreaks,
            BreakCount = 6,
            ColorRamp = colorRampFound.ColorRamp,
            SymbolTemplate = SymbolFactory.Instance.ConstructPolygonSymbol(
                                  ColorFactory.Instance.GreenRGB, SimpleFillStyle.Solid, null).MakeSymbolReference(),
            ExclusionClause = "CROP_ACR07 = -99",
            ExclusionSymbol = SymbolFactory.Instance.ConstructPolygonSymbol(
                                  ColorFactory.Instance.RedRGB, SimpleFillStyle.Solid, null).MakeSymbolReference(),
            ExclusionLabel = "No yield",
        var featureLayerCreationParams = new FeatureLayerCreationParams((new Uri(@"c:\Data\CountyData.gdb\Counties")))
            Name = "Crop",
            RendererDefinition = gcDef
        LayerFactory.Instance.CreateLayer<FeatureLayer>(featureLayerCreationParams, MapView.Active.Map);
    Class Breaks renderer with graduated colors.
    /// <summary>
    /// Renders a feature layer using graduated colors to draw quantities.
    /// ![cb-colors.png](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/cb-colors.png "Graduated colors with natural breaks renderer.")
    /// </summary>
      //Check feature layer name
      //Code works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data
      var featureLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(f => f.Name == "USDemographics");
      if (featureLayer == null)
        MessageBox.Show("This renderer works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data", "Data missing");
        ClassificationField = "NumericFieldInFeatureLayer",
        ClassificationMethod = ClassificationMethod.NaturalBreaks,
        BreakCount = 5,
        ColorRamp = colorRamp,
      //Note: Run within QueuedTask
      CIMClassBreaksRenderer renderer = (CIMClassBreaksRenderer)featureLayer.CreateRenderer(gcDef);
      featureLayer?.SetRenderer(renderer);
    Class Breaks renderer with graduated colors and outline
    /// <summary>
    /// Renders a feature layer using graduated colors to draw quantities. The outline width is varied based on attributes.
    /// ![graduatedColorOutline.png](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/graduatedColorOutline.png "Graduated colors with natural breaks renderer.")
    /// </summary>
      //Gets the first numeric field of the feature layer
      var firstNumericFieldOfFeatureLayer = "NumericFieldInFeatureLayer";
      //Gets the min and max value of the field
      var minMax = GetFieldMinMax(featureLayer, firstNumericFieldOfFeatureLayer);
        BreakCount = 5,
      //Create array of CIMVisualVariables to hold the outline information.
      var visualVariables = new CIMVisualVariable[] {
                  new CIMSizeVisualVariable
                      ValueExpressionInfo = new CIMExpressionInfo
                         Title = "Custom",
                         Expression = "$feature.AREA",
                         ReturnType = ExpressionReturnType.Default
                      AuthoringInfo = new CIMVisualVariableAuthoringInfo
                          MinSliderValue = Convert.ToDouble(minMax.Item1),
                          MaxSliderValue = Convert.ToDouble(minMax.Item2),
                          ShowLegend = false,
                          Heading = firstNumericFieldOfFeatureLayer
                      VariableType = SizeVisualVariableType.Graduated,
                      Target = "outline",
                      MinSize = 1,
                      MaxSize = 13,
                      MinValue = Convert.ToDouble(minMax.Item1),
                      MaxValue = Convert.ToDouble(minMax.Item2)
      renderer.VisualVariables = visualVariables;
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.LayerDrawingDefinition
          ArcGIS.Desktop.Mapping.RendererDefinition
             ArcGIS.Desktop.Mapping.ClassBreaksRendererDefinition
                ArcGIS.Desktop.Mapping.GraduatedColorsRendererDefinition
    Requirements
