ArcGIS.Desktop.Mapping Namespace / FeatureLayer Class / SetRenderer Method / SetRenderer(CIMRenderer) Method
Your custom renderer that will be used to draw features of the feature layer.
Example
    Specifies the feature layer's renderer object which determines how the layer draws. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetRenderer(
       CIMRenderer renderer
    Public Overloads Sub SetRenderer( _
       ByVal renderer As CIMRenderer _
    Parameters
    renderer
    Exceptions
    ExceptionDescription
    Cannot set renderer for layer.
    Remarks
    Use CanSetRenderer to determine if the renderer is valid for the layer before updating it.
    Use FeatureLayer.CreateRenderer to create a new renderer.
    Example
    Modify renderer using Arcade
      await QueuedTask.Run(() =>
        // GetRenderer from Layer (assumes it is a unique value renderer)
        if (featureLayer.GetRenderer() is not CIMUniqueValueRenderer uvRenderer)
          // not a unique value renderer, leave
          return;
        //layer has STATE_NAME field if using the community sample Data\Admin\AdminSample.aprx
        string expression = "if ($view.scale > 21000000) { return $feature.STATE_NAME } else { return 'All' }";
        CIMExpressionInfo updatedExpressionInfo = new()
          Expression = expression,
          Title = "Custom" // can be any string used for UI purpose.
        //set the renderer's expression
        uvRenderer.ValueExpressionInfo = updatedExpressionInfo;
        //SetRenderer on Layer
        featureLayer.SetRenderer(uvRenderer);
    How to set symbol for a feature layer symbolized with simple renderer
      //Get simple renderer from the feature layer
      CIMSimpleRenderer currentRenderer = featureLayer.GetRenderer() as CIMSimpleRenderer;
      if (currentRenderer == null)
        return;
      //Set symbol's real world setting to be the same as that of the feature layer
      symbol.SetRealWorldUnits(featureLayer.UsesRealWorldSymbolSizes);
      //Update the symbol of the current simple renderer
      currentRenderer.Symbol = symbol.MakeSymbolReference();
      //Update the feature layer renderer
        featureLayer.SetRenderer(currentRenderer);
    How to apply a symbol from style to a feature layer
        return;
      //Get symbol from the SymbolStyleItem
      CIMSymbol symbolToApply = symbolStyleItem.Symbol;
      symbolToApply.SetRealWorldUnits(featureLayer.UsesRealWorldSymbolSizes);
      currentRenderer.Symbol = symbolToApply.MakeSymbolReference();
    How to apply a point symbol from a style to a feature layer
          //Get the ArcGIS 2D System style from the Project
          var arcGIS2DStyle =
    Project.Current.GetItems<StyleProjectItem>().FirstOrDefault(s => s.Name == "ArcGIS 2D");
          //Search for the symbolName style items within the ArcGIS 2D style project item.
          var items = arcGIS2DStyle.SearchSymbols(StyleItemType.PointSymbol, "Circle 1");
          //Gets the CIMSymbol
          CIMSymbol symbolToUse = items.FirstOrDefault().Symbol;
          //Get the renderer of the point feature layer
          CIMSimpleRenderer renderer = featureLayer.GetRenderer() as CIMSimpleRenderer;
          symbolToUse.SetRealWorldUnits(featureLayer.UsesRealWorldSymbolSizes);
          //Apply the symbol to the feature layer's current renderer
          renderer.Symbol = symbolToUse.MakeSymbolReference();
          //Apply the renderer to the feature layer
            featureLayer.SetRenderer(renderer);
    How to apply a color ramp from a style to a feature layer
      List<string> fields = new List<string>() { "Field1" };
      var project = Project.Current;
        StyleProjectItem styleToUse =
          project.GetItems<StyleProjectItem>()
              .FirstOrDefault(s => s.Name == "ColorBrewer Schemes (RGB)");
        if (style == null)
          return;
        var colorRampListFound = styleToUse.SearchColorRamps("Red-Gray (10 Classes)");
        if (colorRampListFound == null || colorRampListFound.Count == 0)
          return;
        CIMColorRamp cimColorRamp = null;
        CIMRenderer renderer = null;
        cimColorRamp = colorRampListFound[0].ColorRamp;
        var rendererDef = new UniqueValueRendererDefinition(fields, null, cimColorRamp);
        renderer = featureLayer?.CreateRenderer(rendererDef);
        featureLayer?.SetRenderer(renderer);
    Apply Symbology to a layer from a Layer file
      IEnumerable<FeatureLayer> featureLayers = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>()
        .Where(l => l.ShapeType == esriGeometryType.esriGeometryPoint);
      var layerFile = @"C:\Data\SDK\UniqueValuePointLayer.lyrx";
      foreach (var featureLayerToSymbolize in featureLayers)
        //Get the Layer Document from the lyrx file
        var lyrDocFromLyrxFile = new LayerDocument(layerFile);
        var cimLyrDoc = lyrDocFromLyrxFile.GetCIMLayerDocument();
        //Get the renderer from the layer file
        var rendererFromLayerFile = ((CIMFeatureLayer)cimLyrDoc.LayerDefinitions[0]).Renderer as CIMUniqueValueRenderer;
        //Note: If working with a raster layer, use the SetColorizer method.
        featureLayerToSymbolize?.SetRenderer(rendererFromLayerFile);
    Set unique value renderer to the selected feature layer of the active map
      //field to be used to retrieve unique values
      var fields = new List<string> { "Type" };
      //constructing a point symbol as a template symbol
      CIMPointSymbol pointSym = SymbolFactory.Instance.ConstructPointSymbol(
          ColorFactory.Instance.GreenRGB, 16.0, SimpleMarkerStyle.Pushpin);
      CIMSymbolReference symbolPointTemplate = pointSym.MakeSymbolReference();
      //constructing renderer definition for unique value renderer
      UniqueValueRendererDefinition uniqueValueRendererDef =
    new UniqueValueRendererDefinition(fields, symbolPointTemplate);
      //creating a unique value renderer
      CIMUniqueValueRenderer uniqueValueRenderer = featureLayer.CreateRenderer(uniqueValueRendererDef) as CIMUniqueValueRenderer;
      //setting the renderer to the feature layer
      featureLayer.SetRenderer(uniqueValueRenderer);
    Create a UniqueValueRenderer to specify symbols to values
      //The goal is to construct the CIMUniqueValueRenderer which will be applied to the feature layer.
      // To do this, the following are the objects we need to set the renderer up with the fields and symbols.
      // As a reference, this is the USCities dataset. Snippet will create a unique value renderer that applies
      // specific symbols to all the cities in California and Alabama.  The rest of the cities will use a default symbol.
      // First create a "CIMUniqueValueClass" for the cities in Alabama.
      List<CIMUniqueValue> listUniqueValuesAlabama = new List<CIMUniqueValue> { new CIMUniqueValue { FieldValues = new string[] { "Alabama" } } };
      CIMUniqueValueClass alabamaUniqueValueClass = new CIMUniqueValueClass
        Editable = true,
        Label = "Alabama",
        Patch = PatchShape.Default,
        Symbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB).MakeSymbolReference(),
        Visible = true,
        Values = listUniqueValuesAlabama.ToArray()
      // Create a "CIMUniqueValueClass" for the cities in California.
      List<CIMUniqueValue> listUniqueValuescalifornia = new List<CIMUniqueValue> { new CIMUniqueValue { FieldValues = new string[] { "California" } } };
      CIMUniqueValueClass californiaUniqueValueClass = new CIMUniqueValueClass
        Editable = true,
        Label = "California",
        Symbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.BlueRGB).MakeSymbolReference(),
        Visible = true,
        Values = listUniqueValuescalifornia.ToArray()
      //Create a list of the above two CIMUniqueValueClasses
      List<CIMUniqueValueClass> listUniqueValueClasses = new List<CIMUniqueValueClass>
                    alabamaUniqueValueClass, californiaUniqueValueClass
      //Create a list of CIMUniqueValueGroup
      CIMUniqueValueGroup uvg = new CIMUniqueValueGroup
        Classes = listUniqueValueClasses.ToArray(),
      List<CIMUniqueValueGroup> listUniqueValueGroups = new List<CIMUniqueValueGroup> { uvg };
      //Create the CIMUniqueValueRenderer
      CIMUniqueValueRenderer uvr = new CIMUniqueValueRenderer
        UseDefaultSymbol = true,
        DefaultLabel = "all other values",
        DefaultSymbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.GreyRGB).MakeSymbolReference(),
        Groups = listUniqueValueGroups.ToArray(),
        Fields = new string[] { "STATE_NAME" }
      //Set the feature layer's renderer.
      featureLayer.SetRenderer(uvr);
    Create a Heatmap Renderer
      string colorBrewerSchemesName = "ArcGIS Colors";
      //Get the style project item that contains the color ramps
      //Refer to the Initialize region for an example of how to get a style item
      //and the color ramp from it.
      //defining a heatmap renderer that uses values from Population field as the weights
      HeatMapRendererDefinition heatMapDef = new HeatMapRendererDefinition()
        Radius = 20,
        WeightField = "Population",
        ColorRamp = colorRamp,
        RendereringQuality = 8,
        UpperLabel = "High Density",
        LowerLabel = "Low Density"
      CIMHeatMapRenderer heatMapRndr = featureLayer.CreateRenderer(heatMapDef) as CIMHeatMapRenderer;
      featureLayer.SetRenderer(heatMapRndr);
    Use Arcade expression to create Class Breaks
      var usaStatesLayer = map.GetLayersAsFlattenedList().OfType<FeatureLayer>()
                     .FirstOrDefault(fl => fl.Name == "USA States");
      if (usaStatesLayer == null)
        return;
      //Create a color ramp from red to blue
      var colorRampForPopulation = ColorFactory.Instance.ConstructColorRamp(
            ColorRampAlgorithm.LinearContinuous,
            ColorFactory.Instance.RedRGB, ColorFactory.Instance.BlueRGB);
      //This Arcade expression categorizes the POP2000 field in the usaStates layer
      //into Low, Medium, and High values
      var arcade = @"if ($feature.POP2000 < 1000000)
                       {return ""Low"";}" +
                   @"else if ($feature.POP2000 >= 100000 && $feature.POP2000 < 5000000)
                      {return ""Medium""; }" +
                    @"else if ($feature.POP2000 >= 5000000)
                      {return ""High"";}" +
                    @"else{return ""NA"";}";
      //Create the Arcade expression info
      CIMExpressionInfo arcadeExp = new CIMExpressionInfo();
      arcadeExp.Expression = arcade;
      arcadeExp.ReturnType = ExpressionReturnType.Default;
      arcadeExp.Title = "State Population Categorized";
      arcadeExp.Name = "USA States Population 2000";
      //Each population category is assigned a color from the color ramp and symbolized on the map
      // using a unique value renderer
      var uvr_desc = new UniqueValueRendererDefinition()
        //ValueFields = new List<string> { "STATION" },
        ColorRamp = colorRampForPopulation,
        ValuesLimit = 100,
        ArcadeExpression = arcadeExp.Expression
      //Create the renderer and assign it to the layer
      var renderer = usaStatesLayer.CreateRenderer(uvr_desc);
      usaStatesLayer.SetRenderer(renderer);
    Create an unclassed Renderer
      CIMPointSymbol pointSym = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.GreenRGB, 16.0, SimpleMarkerStyle.Diamond);
      //defining an unclassed renderer with custom upper and lower stops
      //all features with value >= 5,000,000 will be drawn with the upper color from the color ramp
      //all features with value <= 50,000 will be drawn with the lower color from the color ramp
      UnclassedColorsRendererDefinition unclassRndrDef = new UnclassedColorsRendererDefinition
                            ("Population", symbolPointTemplate, colorRamp, "Highest", "Lowest", 5000000, 50000)
        //drawing features with null values with a different symbol
        ShowNullValues = true,
        NullValueLabel = "Unknown"
      // Create a point symbol for null values
      CIMPointSymbol nullSym = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB, 16.0, SimpleMarkerStyle.Circle);
      unclassRndrDef.NullValueSymbol = nullSym.MakeSymbolReference();
      //Create the unclassed renderer using the definition
      CIMClassBreaksRenderer cbRndr = featureLayer.CreateRenderer(unclassRndrDef) as CIMClassBreaksRenderer;
      //Set the renderer to the feature layer
      featureLayer.SetRenderer(cbRndr);
    Create a Proportion Renderer with max and min symbol size capped
      //Creating a point symbol to be used as a template symbol for the proportional renderer
      CIMPointSymbol pointSym = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.GreenRGB, 1.0, SimpleMarkerStyle.Circle);
      //minimum symbol size is capped to 4 point while the maximum symbol size is set to 50 point
      //Creating a proportional renderer definition that uses the "Population" field
      ProportionalRendererDefinition prDef = new ProportionalRendererDefinition("POPULATION", symbolPointTemplate, 4, 50, true)
        //setting upper and lower size stops to stop symbols growing or shrinking beyond those thresholds
        UpperSizeStop = 5000000,  //features with values >= 5,000,000 will be drawn with maximum symbol size
        LowerSizeStop = 50000    //features with values <= 50,000 will be drawn with minimum symbol size
      // Create a proportional renderer using the definition
      CIMProportionalRenderer propRndr = featureLayer.CreateRenderer(prDef) as CIMProportionalRenderer;
      // Set the renderer to the feature layer
      featureLayer.SetRenderer(propRndr);
    Create a True Proportion Renderer
      //Defining proportional renderer where size of symbol will be same as its value in field used in the renderer.
      ProportionalRendererDefinition prDef = new ProportionalRendererDefinition("POPULATION", esriUnits.esriMeters, symbolPointTemplate, SymbolShapes.Square, ValueRepresentations.Radius);
      //Create a Proportional renderer using the definition
    Pie chart renderer for a feature layer
    /// <summary>
    /// Renders a feature layer using Pie chart symbols to represent data
    /// ![Pie chart renderer](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/pie-chart.png)
    /// </summary>
      //Check feature layer name
      //Code works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data
      var featureLayer = activeMap.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(f => f.Name == "USDemographics");
      if (featureLayer == null)
        MessageBox.Show("This renderer works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data", "Data missing");
        //Fields to use for the pie chart slices
        var chartFields = new List<string>
              "WHITE10",
               "BLACK10",
               "AMERIND10",
               "ASIAN10",
               "HISPPOP10",
               "HAMERIND10",
               "HWHITE10",
               "HASIAN10",
               "HPACIFIC10",
               "HBLACK10",
                "HOTHRACE10"
        PieChartRendererDefinition pieChartRendererDefn = new PieChartRendererDefinition()
          ChartFields = chartFields,
          SizeOption = PieChartSizeOptions.Field,
          FieldName = "BLACK10",
          FixedSize = 36.89,
          DisplayIn3D = true,
          ShowOutline = true,
          Orientation = PieChartOrientation.CounterClockwise,
        //Creates a "Renderer"
        var pieChartRenderer = featureLayer.CreateRenderer(pieChartRendererDefn);
        //Sets the renderer to the feature layer
        featureLayer.SetRenderer(pieChartRenderer);
    Bar Chart Value renderer for a feature layer
    /// <summary>
    /// Renders a feature layer using Bar chart symbols to represent data
    /// ![bar chart renderer](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/bar-chart.png)
    /// </summary>
            "WHITE10",
              "BLACK10",
              "AMERIND10",
              "ASIAN10",
              "HISPPOP10",
              "HAMERIND10",
              "HWHITE10",
              "HASIAN10",
              "HPACIFIC10",
              "HBLACK10",
              "HOTHRACE10"
        BarChartRendererDefinition barChartRendererDefn = new BarChartRendererDefinition()
          BarWidth = 12,
          BarSpacing = 1,
          MaximumBarLength = 65,
          Orientation = ChartOrientation.Vertical,
          DisplayIn3D = true,
          ShowAxes = true,
        var barChartChartRenderer = featureLayer.CreateRenderer(barChartRendererDefn);
        featureLayer.SetRenderer(barChartChartRenderer);
    Stacked bar chart renderer for a feature layer
    /// <summary>
    /// Renders a feature layer using stacked bar chart symbols to represent data
    /// ![stacked bar chart renderer](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/stacked-bar-chart.png)
    /// </summary>
              "WHITE10",
               "BLACK10",
               "AMERIND10",
               "ASIAN10",
               "HISPPOP10",
               "HAMERIND10",
               "HWHITE10",
               "HASIAN10",
               "HPACIFIC10",
               "HBLACK10",
                "HOTHRACE10"
      StackedChartRendererDefinition barChartpieChartRendererDefn = new StackedChartRendererDefinition()
        SizeOption = StackChartSizeOptions.SumSelectedFields,
        Orientation = ChartOrientation.Horizontal,
        ShowOutline = true,
        DisplayIn3D = true,
        StackWidth = 8,
        StackLength = 25.87,
        var stackedBarChartChartRenderer = featureLayer.CreateRenderer(barChartpieChartRendererDefn);
        featureLayer.SetRenderer(stackedBarChartChartRenderer);
    Class Breaks renderer with graduated colors.
    /// <summary>
    /// Renders a feature layer using graduated colors to draw quantities.
    /// ![cb-colors.png](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/cb-colors.png "Graduated colors with natural breaks renderer.")
    /// </summary>
      GraduatedColorsRendererDefinition gcDef = new GraduatedColorsRendererDefinition()
        ClassificationField = "NumericFieldInFeatureLayer",
        ClassificationMethod = ClassificationMethod.NaturalBreaks,
        BreakCount = 5,
        CIMClassBreaksRenderer renderer = (CIMClassBreaksRenderer)featureLayer.CreateRenderer(gcDef);
    Class Breaks renderer with graduated colors and outline
    /// <summary>
    /// Renders a feature layer using graduated colors to draw quantities. The outline width is varied based on attributes.
    /// ![graduatedColorOutline.png](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/graduatedColorOutline.png "Graduated colors with natural breaks renderer.")
    /// </summary>
      //Gets the first numeric field of the feature layer
      var firstNumericFieldOfFeatureLayer = "NumericFieldInFeatureLayer";
      //Gets the min and max value of the field
      var minMax = await GetFieldMinMaxAsync(featureLayer, firstNumericFieldOfFeatureLayer);
        BreakCount = 5,
      CIMClassBreaksRenderer renderer = await QueuedTask.Run(() =>
        (CIMClassBreaksRenderer)featureLayer.CreateRenderer(gcDef));
      //Create array of CIMVisualVariables to hold the outline information.
      var visualVariables = new CIMVisualVariable[] {
                  new CIMSizeVisualVariable
                      ValueExpressionInfo = new CIMExpressionInfo
                         Title = "Custom",
                         Expression = "$feature.AREA",
                      AuthoringInfo = new CIMVisualVariableAuthoringInfo
                          MinSliderValue = Convert.ToDouble(minMax.Item1),
                          MaxSliderValue = Convert.ToDouble(minMax.Item2),
                          ShowLegend = false,
                          Heading = firstNumericFieldOfFeatureLayer
                      VariableType = SizeVisualVariableType.Graduated,
                      Target = "outline",
                      MinSize = 1,
                      MaxSize = 13,
                      MinValue = Convert.ToDouble(minMax.Item1),
                      MaxValue = Convert.ToDouble(minMax.Item2)
      renderer.VisualVariables = visualVariables;
      await QueuedTask.Run(() => featureLayer?.SetRenderer(renderer));
    Class Breaks renderer with graduated symbols.
    /// <summary>
    /// Renders a feature layer using graduated symbols and natural breaks to draw quantities.
    /// ![cb-symbols.png](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/cb-symbols.png "Graduated symbols with natural breaks renderer.")
    /// </summary>
      GraduatedSymbolsRendererDefinition gsDef = new GraduatedSymbolsRendererDefinition()
        ClassificationField = "NumericFieldInFeatureLayer", //getting the first numeric field
        SymbolTemplate = SymbolFactory.Instance.ConstructPointSymbol(CIMColor.CreateRGBColor(76, 230, 0)).MakeSymbolReference(),
        MinimumSymbolSize = 4,
        MaximumSymbolSize = 50,
        BreakCount = 5,
        ColorRamp = colorRamp, //getting a color ramp
        CIMClassBreaksRenderer renderer = (CIMClassBreaksRenderer)featureLayer.CreateRenderer(gsDef);
    UnClassed graduated color renderer.
    /// <summary>
    /// Renders a feature layer using an unclassed color gradient.
    /// ![cb-unclassed.png](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/cb-unclassed.png "Class breaks unclassed renderer.")
    /// </summary>
      var featureLayer = activeMap.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(f => f.Name == "U.S. National Transportation Atlas Interstate Highways");
        MessageBox.Show("This renderer works with the U.S. National Transportation Atlas Interstate Highways feature layer available with the ArcGIS Pro SDK Sample data", "Data missing");
      //Refer to the GetFieldMinMax function below
      var labels = await GetFieldMinMaxAsync(featureLayer, firstNumericFieldOfFeatureLayer);
      UnclassedColorsRendererDefinition ucDef = new UnclassedColorsRendererDefinition()
        Field = firstNumericFieldOfFeatureLayer,
        LowerColorStop = Convert.ToDouble(labels.Item1),
        UpperColorStop = Convert.ToDouble(labels.Item2),
        UpperLabel = labels.Item2,
        LowerLabel = labels.Item1,
        CIMClassBreaksRenderer renderer = (CIMClassBreaksRenderer)featureLayer.CreateRenderer(ucDef);
    Class Breaks renderer with Manual Intervals
    /// <summary>
    /// Renders a feature layer using graduated colors and manual intervals to draw quantities.
    /// ![cb-colors-manual-breaks.png](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/cb-colors-manual-breaks.png)
    /// </summary>
      //Change these class breaks to be appropriate for your data. These class breaks defined below apply to the US States feature class
      List<CIMClassBreak> listClassBreaks = new List<CIMClassBreak>
              new CIMClassBreak
                  Symbol = SymbolFactory.Instance.ConstructPolygonSymbol(ColorFactory.Instance.RedRGB).MakeSymbolReference(),
                  UpperBound = 24228
              new CIMClassBreak
                  Symbol = SymbolFactory.Instance.ConstructPolygonSymbol(ColorFactory.Instance.GreenRGB).MakeSymbolReference(),
                  UpperBound = 67290
              new CIMClassBreak
                  Symbol = SymbolFactory.Instance.ConstructPolygonSymbol(ColorFactory.Instance.BlueRGB).MakeSymbolReference(),
                  UpperBound = 121757
               new CIMClassBreak
                  Symbol = SymbolFactory.Instance.ConstructPolygonSymbol(ColorFactory.Instance.GreyRGB).MakeSymbolReference(),
                  UpperBound = 264435
                new CIMClassBreak
                  Symbol = SymbolFactory.Instance.ConstructPolygonSymbol(ColorFactory.Instance.WhiteRGB).MakeSymbolReference(),
                  UpperBound = 576594
      CIMClassBreaksRenderer cimClassBreakRenderer = new CIMClassBreaksRenderer
        ClassBreakType = ClassBreakType.GraduatedColor,
        ClassificationMethod = ClassificationMethod.Manual,
        Field = "NumericFieldInLayer",
        //Important to add the Minimum break for your data to be classified correctly.
        //This is vital especially if you have data with negative values.
        //MinimumBreak =
        Breaks = listClassBreaks.ToArray()
      await QueuedTask.Run(() => featureLayer?.SetRenderer(cimClassBreakRenderer));
    Dot Density renderer.
    /// <summary>
    /// Renders a polygon feature layer with Dot Density symbols to represent quantities.
    /// ![Dot Density renderer](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/dotDensity-renderer.png)
    /// </summary>
      //Define size of the dot to use for the renderer
      int dotSize = 3;
      //Check if the TOTPOP10 field exists
      int idxField = -1;
      idxField = await QueuedTask.Run(() =>
        using var table = featureLayer.GetTable();
        var def = table.GetDefinition();
        return def.FindField("TOTPOP10");
      // "TOTPOP10" field was not found
      if (idxField == -1)
        return;
      //array of fields to be represented in the renderer
      var valueFields = new List<string> { "TOTPOP10" };
        //Create the DotDensityRendererDefinition object
        var dotDensityDef = new DotDensityRendererDefinition(valueFields, colorRamp,
        dotSize, 30000, "Dot", "people");
      //Create the renderer using the DotDensityRendererDefinition
      CIMDotDensityRenderer dotDensityRndr = (CIMDotDensityRenderer)featureLayer.CreateRenderer(dotDensityDef);
      //if you want to customize the dot symbol for the renderer, create a "DotDensitySymbol" which is an
      //Amalgamation of 3 symbol layers: CIMVectorMarker, CIMSolidFill and CIMSolidStroke
      //Define CIMVectorMarker layer
      var cimMarker = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.RedRGB, dotSize);
      var dotDensityMarker = cimMarker as CIMVectorMarker;
      //Define the placement
      CIMMarkerPlacementInsidePolygon markerPlacement = new CIMMarkerPlacementInsidePolygon { Randomness = 100, GridType = PlacementGridType.RandomFixedQuantity, Clipping = PlacementClip.RemoveIfCenterOutsideBoundary };
      dotDensityMarker.MarkerPlacement = markerPlacement;
      //Define CIMSolidFill layer
      CIMSolidFill solidFill = new CIMSolidFill { Color = new CIMRGBColor { R = 249, G = 232, B = 189, Alpha = 50 } };
      //Define CIMSolidStroke
      CIMSolidStroke solidStroke = new CIMSolidStroke { Color = ColorFactory.Instance.GreyRGB, Width = .5 };
      //Create the amalgamated CIMPolygonSymbol that includes the 3 layers
      var dotDensitySymbol = new CIMPolygonSymbol
        SymbolLayers = new CIMSymbolLayer[] { dotDensityMarker, solidFill, solidStroke }
      //Apply the dotDensitySymbol to the CIMDotDenstityRenderer's DotDensitySymbol property.
      dotDensityRndr.DotDensitySymbol = dotDensitySymbol.MakeSymbolReference();
      //Apply the renderer to the polygon Feature Layer.
        featureLayer.SetRenderer(dotDensityRndr);
    Heat map renderer
    /// <summary>
    /// Renders a point feature layer using a continuous color gradient to represent density of points.
    /// ![Heat map renderer](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/heat-map.png)
    /// </summary>
      //Code works with the U.S. Cities feature layer available with the ArcGIS Pro SDK Sample data
      var featureLayer = activeMap.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(f => f.Name == "U.S. Cities");
        MessageBox.Show("This renderer works with the U.S. Cities feature layer available with the ArcGIS Pro SDK Sample data", "Data missing");
        Radius = 20,
        WeightField = "NumericField",
        CIMHeatMapRenderer heatMapRndr = (CIMHeatMapRenderer)featureLayer.CreateRenderer(heatMapDef);
    Proportional symbols renderer.
    /// <summary>
    /// Renders a feature layer using proportional symbols to draw quantities.
    /// ![Proportional Symbols renderer](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/proportional-renderer.png)
    /// </summary>
      var firstNumericFieldOfFeatureLayer = "NumericFieldInLayer";
      var sizes = await GetFieldMinMaxAsync(featureLayer, firstNumericFieldOfFeatureLayer);
      ProportionalRendererDefinition prDef = new ProportionalRendererDefinition()
        LowerSizeStop = Convert.ToDouble(sizes.Item1),
        UpperSizeStop = Convert.ToDouble(sizes.Item2)
        CIMProportionalRenderer propRndr = (CIMProportionalRenderer)featureLayer.CreateRenderer(prDef);
    Simple Renderer for a Polygon feature layer.
    /// <summary>
    /// Renders a Polygon feature layer using a single symbol.
    /// ![Simple Renderer for Polygon features](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/simple-polygon.png)
    /// </summary>
      //Creating a polygon with a red fill and blue outline.
      CIMStroke outline = SymbolFactory.Instance.ConstructStroke(
            ColorFactory.Instance.BlueRGB, 2.0, SimpleLineStyle.Solid);
      CIMPolygonSymbol fillWithOutline = SymbolFactory.Instance.ConstructPolygonSymbol(
            ColorFactory.Instance.CreateRGBColor(255, 190, 190), SimpleFillStyle.Solid, outline);
        //Get the layer's current renderer
        renderer.Symbol = fillWithOutline.MakeSymbolReference();
    Simple Renderer for a Point feature layer.
    /// <summary>
    /// Renders a Point feature layer using a single symbol.
    /// ![Simple Renderer for Point features](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/simple-point.png)
    /// </summary>
      var featureLayer = activeMap.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(f => f.ShapeType == esriGeometryType.esriGeometryPoint);
        MessageBox.Show("This renderer works with a point feature layer", "Data missing");
      //Create a circle marker
      var pointSymbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB, 8, SimpleMarkerStyle.Circle);
        renderer.Symbol = pointSymbol.MakeSymbolReference();
    Simple Renderer for a Line feature layer.
    /// <summary>
    /// Renders a Line feature layer using a single symbol.
    /// ![Simple Renderer for Line features](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/simple-line.png)
    /// </summary>
      var lineSymbol = SymbolFactory.Instance.ConstructLineSymbol(ColorFactory.Instance.RedRGB, 2, SimpleLineStyle.DashDotDot);
        renderer.Symbol = lineSymbol.MakeSymbolReference();
    Simple Renderer for a Line feature layer using a style from a StyleProjectItem.
    /// <summary>
    /// Renders a Line feature layer using a style from a StyleProjectItem.
    /// ![Simple Renderer Style item](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/simple-line-style-item.png)
    /// </summary>
      //Get all styles in the project
      var styleProjectItem2D = project.GetItems<StyleProjectItem>().FirstOrDefault(s => s.Name == "ArcGIS 2D");
      //Get a specific style in the project by name
      var arrowLineSymbol = styleProjectItem2D.SearchSymbols(StyleItemType.LineSymbol, "Arrow Line 2 (Mid)")[0];
      if (arrowLineSymbol == null)
        return;
        var renderer = featureLayer?.GetRenderer() as CIMSimpleRenderer;
        renderer.Symbol = arrowLineSymbol.Symbol.MakeSymbolReference();
    Unique Value Renderer for a feature layer
    /// <summary>
    /// Renders a feature layer using unique values from one or multiple fields
    /// ![Unique Value renderer](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/unique-value.png)
    /// </summary>
      //construct unique value renderer definition
      UniqueValueRendererDefinition uvr = new
        //Refer to the function below to get a display field of the feature layer
        ValueFields = new List<string> { await GetDisplayFieldAsync(featureLayer) }, //multiple fields in the array if needed.
        ColorRamp = colorRamp, //Specify color ramp
        var cimRenderer = featureLayer.CreateRenderer(uvr);
        featureLayer.SetRenderer(cimRenderer);
      //Function to get the display field of a feature layer
      static Task<string> GetDisplayFieldAsync(FeatureLayer featureLayer)
        return QueuedTask.Run(() =>
          // get the CIM definition from the layer
          var cimFeatureDefinition = featureLayer.GetDefinition() as ArcGIS.Core.CIM.CIMBasicFeatureLayer;
          // get the view of the source table underlying the layer
          var cimDisplayTable = cimFeatureDefinition.FeatureTable;
          // this field is used as the 'label' to represent the row
          return cimDisplayTable.DisplayField;
    Setting a unique value renderer for latest observations
        var url = @"https://geoeventsample1.esri.com:6443/arcgis/rest/services/AirportTraffics/StreamServer";
        var uri = new Uri(url, UriKind.Absolute);
        var createParams = new FeatureLayerCreationParams(uri)
          IsVisible = false
        streamLayer = LayerFactory.Instance.CreateLayer<StreamLayer>(
                            createParams, map);
        //Define the unique values by hand
        var uvr = new CIMUniqueValueRenderer()
          Fields = new string[] { "ACTYPE" },
          DefaultLabel = "Others",
                      CIMColor.CreateRGBColor(185, 185, 185), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
        var classes = new List<CIMUniqueValueClass>
          //add in classes - one for ACTYPE of 727, one for DC 9
          new CIMUniqueValueClass()
            Values = new CIMUniqueValue[] {
                    new CIMUniqueValue() { FieldValues = new string[] { "B727" } } },
            Visible = true,
            Label = "Boeing 727",
                      ColorFactory.Instance.RedRGB, 10, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
                    new CIMUniqueValue() { FieldValues = new string[] { "DC9" } } },
            Visible = true,
            Label = "DC 9",
                      ColorFactory.Instance.GreenRGB, 10, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
        //add the classes to a group
        var groups = new List<CIMUniqueValueGroup>()
        new CIMUniqueValueGroup() {
           Classes = classes.ToArray()
        //add the groups to the renderer
        uvr.Groups = groups.ToArray();
        //Apply the renderer (for current observations)
        streamLayer.SetRenderer(uvr);
        streamLayer.SetVisibility(true);//turn on the layer
    Defining a unique value renderer definition
        streamLayer = null;
        //https://geoeventsample1.esri.com:6443/arcgis/rest/services/AirportTraffics/StreamServer
        var uvrDef = new UniqueValueRendererDefinition()
          ValueFields = new List<string> { "ACTYPE" },
          ValuesLimit = 5
        //Note: CreateRenderer can only create value classes based on
        //the current events it has received
        streamLayer.SetRenderer(streamLayer.CreateRenderer(uvrDef));
    Setting a unique value renderer for latest observations 2
        //Define the classes by hand to avoid using CreateRenderer(...)
        CIMUniqueValueClass uvcB727 = new CIMUniqueValueClass()
          Values = new CIMUniqueValue[] { new CIMUniqueValue() { FieldValues = new string[] { "B727" } } },
          Visible = true,
          Symbol = SymbolFactory.Instance.ConstructPointSymbol(CIMColor.CreateRGBColor(255, 0, 0), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
        CIMUniqueValueClass uvcD9 = new CIMUniqueValueClass()
          Values = new CIMUniqueValue[] { new CIMUniqueValue() { FieldValues = new string[] { "DC9" } } },
          Visible = true,
          Label = "DC 9",
          Symbol = SymbolFactory.Instance.ConstructPointSymbol(CIMColor.CreateRGBColor(0, 255, 0), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
        //Assign the classes to a group
        CIMUniqueValueGroup uvGrp = new CIMUniqueValueGroup()
          Classes = new CIMUniqueValueClass[] { uvcB727, uvcD9 }
        //assign the group to the renderer
        var UVrndr = new CIMUniqueValueRenderer()
          Groups = new CIMUniqueValueGroup[] { uvGrp },
        //set the renderer. Depending on the current events received, the
        //layer may or may not have events for each of the specified
        //unique value classes
        streamLayer.SetRenderer(UVrndr);
    Setting a unique value renderer for previous observations
      //The layer must be track aware and spatial
      if (streamLayer.TrackType != TrackType.Spatial)
        // not track aware and spatial
        //Define unique value classes same as we do for current observations
        //or use "CreateRenderer(...)" to assign them automatically
        CIMUniqueValueClass uvcB727Prev = new CIMUniqueValueClass()
          Visible = true,
          CIMColor.CreateRGBColor(255, 0, 0), 4, SimpleMarkerStyle.Hexagon)
        CIMUniqueValueClass uvcD9Prev = new CIMUniqueValueClass()
          Visible = true,
          Label = "DC 9",
            CIMColor.CreateRGBColor(0, 255, 0), 4, SimpleMarkerStyle.Hexagon)
        CIMUniqueValueGroup uvGrpPrev = new CIMUniqueValueGroup()
          Classes = new CIMUniqueValueClass[] { uvcB727Prev, uvcD9Prev }
          Groups = new CIMUniqueValueGroup[] { uvGrpPrev },
            CIMColor.CreateRGBColor(185, 185, 185), 4, SimpleMarkerStyle.Hexagon)
        streamLayer.SetRenderer(UVrndr, FeatureRendererTarget.PreviousObservations);
    Requirements
