ArcGIS.Desktop.Mapping Namespace / FeatureLayer Class / CanSetRenderer Method
Your custom renderer that will be used to draw features of the feature layer.
A FeatureRendererTarget indicating the intended usage of the resulting renderer.
    CanSetRenderer Method (FeatureLayer)
    Determines whether a renderer is valid for the feature layer and can be updated. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function CanSetRenderer( _
       ByVal renderer As CIMRenderer, _
       Optional ByVal featureRendererTarget As FeatureRendererTarget _
    ) As Boolean
    Parameters
    renderer
    Return Value
    A boolean indicates that a renderer can be updated for the layer.
    Exceptions
    ExceptionDescription
    Remarks
    Certain renderers are only appropriate for certain layer types or for layers of a certain geometry type. For example a Dot Density Renderer can only be applied to a polygon layer, a Heat Map Renderer can only be applied to a point layer.
    Requirements
