ArcGIS.Desktop.Mapping Namespace / HeatMapRendererDefinition Class / Radius Property
Example
    Radius Property (HeatMapRendererDefinition)
    Gets or sets the radius used for the heat map. Default value is 25.
    Syntax
    Public Property Radius As Integer
    public int Radius {get; set;}
    Example
    Create a Heatmap Renderer
        string colorBrewerSchemesName = "ArcGIS Colors";
        //Get the style project item that contains the color ramps
        //Refer to the Initialize region for an example of how to get a style item
        //and the color ramp from it.
        //Note: Run within a QueuedTask
        //defining a heatmap renderer that uses values from Population field as the weights
        HeatMapRendererDefinition heatMapDef = new HeatMapRendererDefinition()
            Radius = 20,
            WeightField = "Population",
            ColorRamp = colorRamp,
            RendereringQuality = 8,
            UpperLabel = "High Density",
            LowerLabel = "Low Density"
        CIMHeatMapRenderer heatMapRndr = featureLayer.CreateRenderer(heatMapDef) as CIMHeatMapRenderer;
        featureLayer.SetRenderer(heatMapRndr);
    Requirements
