ArcGIS.Desktop.Mapping Namespace / ImageServiceLayer Class / GetMosaicRule Method
Example
    Gets the mosaic rule. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetMosaicRule() As CIMMosaicRule
    public CIMMosaicRule GetMosaicRule()
    Return Value
    Exceptions
    ExceptionDescription
    Example
    Update the sort order - mosaic method on a mosaic layer
        //Note: needs to be called on the QueuedTask
        // Get the image sub-layer from the mosaic layer.
        ImageServiceLayer mosaicImageSubLayer = mosaicLayer.GetImageLayer();
        // Get the mosaic rule.
        CIMMosaicRule mosaicingRule = mosaicImageSubLayer.GetMosaicRule();
        // Set the Mosaic Method to Center.
        mosaicingRule.MosaicMethod = RasterMosaicMethod.Center;
        // Update the mosaic with the changed mosaic rule.
        mosaicImageSubLayer.SetMosaicRule(mosaicingRule);
    Update the resolve overlap - mosaic operator on a mosaic layer
        ImageServiceLayer mosaicImageSublayerToUse = mosaicLayer.GetImageLayer();
        CIMMosaicRule mosaicRule = mosaicImageSublayerToUse.GetMosaicRule();
        // Set the Mosaic Operator to Mean.
        mosaicRule.MosaicOperatorType = RasterMosaicOperatorType.Mean;
        mosaicImageSublayerToUse.SetMosaicRule(mosaicRule);
    Update the sort order - mosaic method on an image service layer
        // Get the mosaic rule of the image service.
        CIMMosaicRule mosaicRule = imageServiceLayer.GetMosaicRule();
        mosaicRule.MosaicMethod = RasterMosaicMethod.Center;
        // Update the image service with the changed mosaic rule.
        imageServiceLayer.SetMosaicRule(mosaicRule);
    Update the resolve overlap - mosaic operator on an image service layer
        CIMMosaicRule mosaicingRule = imageServiceLayer.GetMosaicRule();
        mosaicingRule.MosaicOperatorType = RasterMosaicOperatorType.Mean;
        imageServiceLayer.SetMosaicRule(mosaicingRule);
    Requirements
