ArcGIS.Desktop.Mapping Namespace / ImageServiceLayer Class / SetCompression Method
Type of compression.
Compression quality (if applicable).
    Sets the compression. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetCompression(
       string compression,
       int quality
    Public Sub SetCompression( _
       ByVal compression As String, _
       ByVal quality As Integer _
    Parameters
    compression
    quality
    Exceptions
    ExceptionDescription
    Requirements
