ArcGIS.Desktop.Mapping Namespace / ImageServiceLayer Class / SetMosaicRule Method
ArcGIS.Core.CIM.CIMMosaicRule
Example
    Sets the mosaic rule. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetMosaicRule(
       CIMMosaicRule mosaicRule
    Public Sub SetMosaicRule( _
       ByVal mosaicRule As CIMMosaicRule _
    Parameters
    mosaicRule
    Exceptions
    ExceptionDescription
    Example
    Update the sort order - mosaic method on a mosaic layer
      await QueuedTask.Run(() =>
      // Get the image sub-layer from the mosaic layer.
      ImageServiceLayer mosaicImageSubLayer = mosaicLayer.GetImageLayer();
      // Get the mosaic rule.
      CIMMosaicRule mosaicingRule = mosaicImageSubLayer.GetMosaicRule();
      // Set the Mosaic Method to Center.
      mosaicingRule.MosaicMethod = RasterMosaicMethod.Center;
      // Update the mosaic with the changed mosaic rule.
      mosaicImageSubLayer.SetMosaicRule(mosaicingRule);
    Update the resolve overlap - mosaic operator on a mosaic layer
      ImageServiceLayer mosaicImageSublayerToUse = mosaicLayer.GetImageLayer();
      CIMMosaicRule mosaicRule = mosaicImageSublayerToUse.GetMosaicRule();
      // Set the Mosaic Operator to Mean.
      mosaicRule.MosaicOperatorType = RasterMosaicOperatorType.Mean;
      mosaicImageSublayerToUse.SetMosaicRule(mosaicRule);
    Update the sort order - mosaic method on an image service layer
      // Get the mosaic rule of the image service.
      CIMMosaicRule mosaicRule = imageServiceLayer.GetMosaicRule();
      mosaicRule.MosaicMethod = RasterMosaicMethod.Center;
      // Update the image service with the changed mosaic rule.
      imageServiceLayer.SetMosaicRule(mosaicRule);
    Update the resolve overlap - mosaic operator on an image service layer
      CIMMosaicRule mosaicingRule = imageServiceLayer.GetMosaicRule();
      mosaicingRule.MosaicOperatorType = RasterMosaicOperatorType.Mean;
      imageServiceLayer.SetMosaicRule(mosaicingRule);
    Requirements
