ArcGIS.Desktop.Mapping Namespace / Layer Class / GetDefinition Method
Example
    GetDefinition Method (Layer)
    Returns the layer's CIM definition. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overridable Function GetDefinition() As CIMBaseLayer
    public virtual CIMBaseLayer GetDefinition()
    Return Value
    Exceptions
    ExceptionDescription
    Example
    Hide or show editing tools on templates
    await QueuedTask.Run(() =>
         //hide all tools except line tool on a given feature layer
         var editTemplates = featureLayer.GetTemplates();
         var newCIMEditingTemplates = new List<CIMEditingTemplate>();
         foreach (var et in editTemplates)
           //initialize template by activating default tool
           et.ActivateDefaultToolAsync();
           var cimEditTemplate = et.GetDefinition();
           //get the visible tools on this template
           var allTools = et.ToolIDs.ToList();
           //add the hidden tools on this template
           allTools.AddRange(cimEditTemplate.GetExcludedToolIDs().ToList());
           //hide all the tools then allow the line tool
           cimEditTemplate.SetExcludedToolIDs(allTools.ToArray());
           cimEditTemplate.AllowToolID("esri_editing_SketchLineTool");
           newCIMEditingTemplates.Add(cimEditTemplate);
         //update the layer templates
         var layerDef = featureLayer.GetDefinition() as CIMFeatureLayer;
         // Set AutoGenerateFeatureTemplates to false for template changes to stick
         layerDef.AutoGenerateFeatureTemplates = false;
         layerDef.FeatureTemplates = newCIMEditingTemplates.ToArray();
         featureLayer.SetDefinition(layerDef);
    Access the display field for a layer
        // get the CIM definition from the layer
        // Note: needs to be called on the MCT
        var cimFeatureDefinition = featureLayer.GetDefinition() as ArcGIS.Core.CIM.CIMBasicFeatureLayer;
        // get the view of the source table underlying the layer
        var cimDisplayTable = cimFeatureDefinition.FeatureTable;
        // this field is used as the 'label' to represent the row
        var displayField = cimDisplayTable.DisplayField;
    Edit Color Modulation
      // Note: call within QueuedTask.Run()
        var def = pointCloudSceneLayer.GetDefinition() as CIMPointCloudLayer;
        //Get the ColorModulation off the renderer
        var modulation = def.Renderer.ColorModulation;
        if (modulation == null)
          modulation = new CIMColorModulationInfo();
        //Set the minimum and maximum intensity as needed
        modulation.MinValue = 0;
        modulation.MaxValue = 100.0;
        //apply back
        def.Renderer.ColorModulation = modulation;
        //Commit changes back to the CIM
        pointCloudSceneLayer.SetDefinition(def);
    Edit The Renderer to use Fixed Size
        //Set the point shape and sizing on the renderer
        def.Renderer.PointShape = PointCloudShapeType.DiskShaded;
        var pointSize = new CIMPointCloudFixedSizeAlgorithm()
          UseRealWorldSymbolSizes = false,
          Size = 8
        def.Renderer.PointSizeAlgorithm = pointSize;
    Edit the Renderer to Scale Size
        def.Renderer.PointShape = PointCloudShapeType.DiskFlat;//default
        var scaleSize = new CIMPointCloudSplatAlgorithm()
          MinSize = 8,
          ScaleFactor = 1.0 //100%
        def.Renderer.PointSizeAlgorithm = scaleSize;
    Edit Density settings
        //PointsBudget - corresponds to Display Limit on the UI
        // - the absolute maximum # of points to display
        def.PointsBudget = 1000000;
        //PointsPerInch - corresponds to Density Min --- Max on the UI
        // - the max number of points per display inch to renderer
        def.PointsPerInch = 15;
    Requirements
