ArcGIS.Desktop.Mapping Namespace / Layer Class / QueryExtent Method
(Optional) -true- computes extent of the layer using largest symbol size.
-false- returns the underlying FeatureClass' full extent.
(default value = false)
    QueryExtent Method
    Returns extent of the layer optionally taking symbol size in account. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function QueryExtent( _
       Optional ByVal includeSymbolSize As Boolean _
    ) As Envelope
    public Envelope QueryExtent(
       bool includeSymbolSize
    Parameters
    includeSymbolSize
    Return Value
    An envelope that covers all features of the layer.
    Exceptions
    ExceptionDescription
    Remarks
    If you want to get extent to zoom to the layer's extent but do not want to see features cut off on edges, you should use
    Requirements
