ArcGIS.Desktop.Mapping Namespace / Layer Class / SetDefinition Method
ArcGIS.Core.CIM.CIMBaseLayer
Example
    SetDefinition Method (Layer)
    Updates the layer's CIM definition. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetDefinition( _
       ByVal baseLayer As CIMBaseLayer _
    public void SetDefinition(
       CIMBaseLayer baseLayer
    Parameters
    baseLayer
    Exceptions
    ExceptionDescription
    Example
    Modify label expression using Arcade
      // Note: the following should be embedded in a QueuedTask.Run() statement
        //Get the layer's definition, using the community sample Data\Admin\AdminSample.aprx
        if (featureLayer.GetDefinition() is not CIMFeatureLayer lyrDefn)
          // not a feature layer, leave
          return;
        //Get the label classes - we need the first one
        var listLabelClasses = lyrDefn.LabelClasses.ToList();
        var theLabelClass = listLabelClasses.FirstOrDefault();
        //set the label class Expression to use the Arcade expression
        theLabelClass.Expression = "return $feature.STATE_NAME + TextFormatting.NewLine + $feature.POP2000;";
        //Set the label definition back to the layer.
        featureLayer.SetDefinition(lyrDefn);
    Move a layer in the 2D group to the 3D Group in a Local Scene
        //The layer in the 2D group to move to the 3D Group in a Local Scene
        //Note: needs to be called on the MCT
        var lyrDefn = featureLayer.GetDefinition() as CIMBasicFeatureLayer;
        //setting this property moves the layer to 3D group in a scene
        lyrDefn.IsFlattened = false;
        //Set the definition back to the layer
    Hide or show editing tools on templates
    await QueuedTask.Run(() =>
         //hide all tools except line tool on a given feature layer
         var editTemplates = featureLayer.GetTemplates();
         var newCIMEditingTemplates = new List<CIMEditingTemplate>();
         foreach (var et in editTemplates)
           //initialize template by activating default tool
           et.ActivateDefaultToolAsync();
           var cimEditTemplate = et.GetDefinition();
           //get the visible tools on this template
           var allTools = et.ToolIDs.ToList();
           //add the hidden tools on this template
           allTools.AddRange(cimEditTemplate.GetExcludedToolIDs().ToList());
           //hide all the tools then allow the line tool
           cimEditTemplate.SetExcludedToolIDs(allTools.ToArray());
           cimEditTemplate.AllowToolID("esri_editing_SketchLineTool");
           newCIMEditingTemplates.Add(cimEditTemplate);
         //update the layer templates
         var layerDef = featureLayer.GetDefinition() as CIMFeatureLayer;
         // Set AutoGenerateFeatureTemplates to false for template changes to stick
         layerDef.AutoGenerateFeatureTemplates = false;
         layerDef.FeatureTemplates = newCIMEditingTemplates.ToArray();
         featureLayer.SetDefinition(layerDef);
    Edit Color Modulation
      // Note: call within QueuedTask.Run()
        var def = pointCloudSceneLayer.GetDefinition() as CIMPointCloudLayer;
        //Get the ColorModulation off the renderer
        var modulation = def.Renderer.ColorModulation;
        if (modulation == null)
          modulation = new CIMColorModulationInfo();
        //Set the minimum and maximum intensity as needed
        modulation.MinValue = 0;
        modulation.MaxValue = 100.0;
        //apply back
        def.Renderer.ColorModulation = modulation;
        //Commit changes back to the CIM
        pointCloudSceneLayer.SetDefinition(def);
    Edit The Renderer to use Fixed Size
        //Set the point shape and sizing on the renderer
        def.Renderer.PointShape = PointCloudShapeType.DiskShaded;
        var pointSize = new CIMPointCloudFixedSizeAlgorithm()
          UseRealWorldSymbolSizes = false,
          Size = 8
        def.Renderer.PointSizeAlgorithm = pointSize;
    Edit the Renderer to Scale Size
        def.Renderer.PointShape = PointCloudShapeType.DiskFlat;//default
        var scaleSize = new CIMPointCloudSplatAlgorithm()
          MinSize = 8,
          ScaleFactor = 1.0 //100%
        def.Renderer.PointSizeAlgorithm = scaleSize;
    Edit Density settings
        //PointsBudget - corresponds to Display Limit on the UI
        // - the absolute maximum # of points to display
        def.PointsBudget = 1000000;
        //PointsPerInch - corresponds to Density Min --- Max on the UI
        // - the max number of points per display inch to renderer
        def.PointsPerInch = 15;
    Requirements
